Help with "Text Contains"
markcrosbie
Re: Help with "Text Contains"
Post by markcrosbie »
Hi John,
I'd certainly welcome a strstr() function, or some equivalent to the PERL split() function. I spent an (enjoyable) afternoon coding a simple text line parser that could parse lines of configuration data from a file (in the format index=x,y). The resulting code looked ugly, but without a strstr() function seemed the best I could come up with.
// Parse the text line and return the x,y coordinates
// Return ERR if the line fails to parse, else return SUCCESS
// Line format is index=x,y<newline>
// Does not tolerate whitespace around numbers
int parseLine(string line, int &index, int &x, int &y) {
	int pos, len;
	int equals, comma; // index of the equals and comma chars in the string
	equals = comma = -1;
	len = strlen(line);
	// Locate the = sign
	for(pos=0; pos < len; pos++) {
		if(StrIndex(line, pos) == EQUAL) {
			equals = pos;
			break;
	if(equals == -1) {
		// no equals
		return ERR;
	index = StrToNum(SubStr(line, 0, equals+1));
	// Now locate the comma
	for( ; pos < len; pos++) {
		if(StrIndex(line, pos) == COMMA) {
			comma = pos;
			break;
	if(comma == -1) {
		// no comma
		return ERR;
	x = StrToNum(SubStr(line, equals+1, (comma - equals) - 1));
	// Whatever is after the comma is the y value
	y = StrToNum(SubStr(line, comma+1, (len - comma) - 1));
	return SUCCESS;
I'm sure you code hand-tune this to be tighter!
Regards,
Mark
afanofosc wrote: Here's a slightly more efficient version that uses a repeat loop rather than a for loop:
bool IsIncluded( string s1, string s2 )
  int l1 = StrLen(s1);
  int lDelta = StrLen(s2)-l1;
  int i = 0;
  repeat(lDelta+1)
    if (s1 == SubStr( s2, i, l1))
      return true;
    i++;
  return false;
I'm curious: You keep saying repeat is a bit faster. Is it defined separately in the firmware? How much faster is it?
Also:
/*  Program Name: "FindString.nxc"
**  This program was created by "muntoo" on December 1, 2010
**  Created using BricxCC (by John Hansen) and written in NXC (by John Hansen)
**  ( http://bricxcc.sourceforge.net/ )
#define FIND_EQUALS	0x00000000
#define FIND_STRCMP	0x00000001
#define FIND_ERROR	0xFFFFFFFF
Find toFind inside buf.
If options is set to FIND_EQUALS, the character values are compared without any API functions.
If options is set to FIND_STRCMP, the strings are compared using strcmp().
Ignores the number of toFinds in buf specified in the skip variable.
unsigned long Find(string buf, string toFind, unsigned long options = FIND_STRCMP, unsigned int skip = 0)
	unsigned int len_buf = StrLen(buf);
	unsigned int len_toFind = StrLen(toFind);
	if(len_buf < len_toFind)
		return(FIND_ERROR);
	bool keepGoing;
	for(unsigned int szIdx = 0; szIdx < len_buf; szIdx++)
		keepGoing = true;
		for(unsigned int szIdx2 = 0; (szIdx2 < len_toFind) && keepGoing; szIdx2++)
			switch(options)
				case FIND_EQUALS:
					if(!(buf[szIdx] == toFind[szIdx2]))
						keepGoing = false;
					break;
				case FIND_STRCMP:
//					if(strcmp(SubStr(buf, szIdx, 1), SubStr(toFind, szIdx2, 1)))
					if(!(strcmp(SubStr(buf, szIdx, 1), SubStr(toFind, szIdx2, 1)) == 0))
						keepGoing = false;
					break;
			szIdx++;
		if(keepGoing == true)
			keepGoing = false;
			if(skip > 0)
				skip--;
				return(szIdx - len_toFind);
	return(FIND_ERROR);
	string buf = "ABCDEF1, deDEf2, deF3, I will kill all of you fools.";
	for(int skip = 0; skip < 4; skip++)
		TextOut(0, skip * 8, SubStr(buf, Find(buf, "DEF", FIND_STRCMP, skip), 4), 0);
	Wait(5000);
I can't guarantee if it works (I haven't tested it out, and the nearest NXT is about 1.5 km away, trying to figure out what 6 times 9 is*), but test out the speed. It may be faster (if stripped of all those extra features, such as skip) than the functions posted earlier.
*42, but don't tell it that; it's meant as a "simple" exercise for the depressed android, M*****.
muntoo wrote: I'm curious: You keep saying repeat is a bit faster. Is it defined separately in the firmware? How much faster is it?
The repeat loop is faster than a for loop because it results in simpler NBC code. That's mainly because the number of loop iterations is known up front. A for loop, on the other hand, needs to check every time it reaches the end of the loop to see if it needs to start the loop over again.
