TextEdit
nxtboyiii
Re: TextEdit
Post by nxtboyiii »
Oh. I know it is possible to make it read more than the first line because I have seen it before.
Re: TextEdit
nxtboyiii wrote:I have enhanced FW 1.21...
I don't think there is such a thing as enhanced firmware 1.21.
Re: TextEdit
sidneys1 wrote:
dudmaster wrote:
  • All bugs fixed
I'm pretty sure chaos theory states that that is wholly impossible ;) Perhaps you should add support for multiline files?
Have a nice day,
~Sidneys1
It's not a bug, it's a feature:
Also, I don't think it was the chaos theory that states that...
dudmaster
Re: TextEdit
Post by dudmaster »
So, how do i do this? (Add multiple line support)
2Labz.com, My Website
Re: TextEdit
I just downloaded the program to look at it, and I see a couple things that you should consider.
I haven't tried the program, but I think you should have the character "0" (zero) in the "Alphabet" array (struct?).
Please indent your code.
Here is an indented version with the 0:
Version 7 Features...
@ FontWrap display
@ AutoVersion capable
@ UNLIMITED letter text! (in Read mode)
@ Tutorial
@ Lastest greatest best GUIs
@ User-friendly design
@ Better graphics
@ Multi-function read/write/delete
@ File lister
@ Automatic file extention detector
@ Automatic loop
#download "TextEdit.ric"
#download "wText.ric"
#download "AreYouSure.ric"
#download "TextDelete.ric"
#download "TextOpen.ric"
#download "TextWrite.ric"
#download "TextOptions.ric"
#download "TextRename.ric"
  SetLongAbort(2);
  string BrickName = BrickDataName();
  string Alphabet[] = {"a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p", "q", "r", "s", "t", "u",
  "v", "w", "x", "y", "z", ".", " ", "!", ",", "(", , ")", "?", "A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "L", "M", "N", "O", "P", "Q", "R", "S", "T",
  "U", "V", "W", "X", "Y", "Z", "0", "1", "2", "3", "4", "5", "6", "7", "8", "9"};
  int LinkNumber, Select;
  int TextX2 = 100, TextX1 = 26;
  GraphicOut(0, 0, "wText.ric", true);
  while (0 == ButtonCount(BTNRIGHT, true) && 0 == Select)
    Select = ButtonCount(BTNLEFT, true);
    if (ButtonCount(BTNEXIT, true))
      Stop(true);
  if (Select == 1)
    TextOut(0, LCD_LINE1, "Use arrow keys", true);
    TextOut(0, LCD_LINE2, "to select option.");
    until (ButtonCount(BTNCENTER, true));
  MainMenu:
  LinkNumber = 0;
  TextX2 = 100;
  TextX1 = 26;
  while (false == ButtonCount(BTNCENTER,true))
    if (LinkNumber == 0)
      GraphicOut(12, 3, "TextRename.ric", true);
      GraphicOut(42, 3, "TextOpen.ric");
      GraphicOut(72, 3, "TextWrite.ric");
      TextOut(3, LCD_LINE5, "      Read");
    if (LinkNumber == 1)
      GraphicOut(72, 3, "TextDelete.ric", true);
      GraphicOut(12, 3, "TextOpen.ric");
      GraphicOut(42, 3, "TextWrite.ric");
      TextOut(0, LCD_LINE5, "      Write");
    if (LinkNumber == 2)
      GraphicOut(42, 3, "TextDelete.ric", true);
      GraphicOut(72, 3, "TextRename.ric");
      GraphicOut(12, 3, "TextWrite.ric");
      TextOut(3, LCD_LINE5, "     Delete");
    if (LinkNumber == 3)
      GraphicOut(42, 3, "TextRename.ric", true);
      GraphicOut(72, 3, "TextOpen.ric");
      GraphicOut(12, 3, "TextDelete.ric");
      TextOut(3, LCD_LINE5, "     Rename");
    GraphicOut(0, LCD_LINE3, "TextEdit.ric");
    RectOut(38, 23, 24, -300);
    TextOut(0, LCD_LINE1, BrickName);
    LineOut(0, 54, 99, 54);
    if (1 == ButtonCount(BTNLEFT,true))
      if (1 == LinkNumber || 2 == LinkNumber || 3 == LinkNumber)
        LinkNumber = LinkNumber - 1;
        LinkNumber = 3;
    if (1 == ButtonCount(BTNRIGHT,true))
      if (0 == LinkNumber || 1 == LinkNumber || 2 == LinkNumber)
        LinkNumber = LinkNumber + 1;
        LinkNumber = 0;
      Stop(true);
    Wait(50);
  if (1 == LinkNumber)
    if (Select == 1)
      TextOut(0, LCD_LINE1, "You have chosen", true);
      TextOut(0, LCD_LINE2, "Write. Type in a");
      TextOut(0, LCD_LINE3, "filename to use");
      TextOut(0, LCD_LINE4, "and then type in");
      TextOut(0, LCD_LINE5, "file content.");
      TextOut(0, LCD_LINE6, "Use exit to");
      TextOut(0, LCD_LINE6, "backspace or exit.");
    WF:
    string Sen = "", Sen2 = "";
    bool S = false;
    byte handle = 0x00;
    int N = 0, LinkNumber = 0, cnt = 0;
    while (S == false){
      while (0 == ButtonCount(BTNCENTER,true)){
        if (ButtonCount(BTNLEFT,true) && N > 0)
          N--;
        if (ButtonCount(BTNRIGHT,true) && N < 69)
          N++;
        Sen2 = Alphabet[N];
        TextOut(0, LCD_LINE1, "File Name:", true);
        TextOut(0, LCD_LINE2, SubStr(Sen + Sen2, 0, 18));
        TextOut(0, LCD_LINE3, SubStr(Sen + Sen2, 16, 18));
        TextOut(0, LCD_LINE4, SubStr(Sen + Sen2, 32, 18));
        TextOut(0, LCD_LINE5, SubStr(Sen + Sen2, 48, 18));
        TextOut(0, LCD_LINE6, SubStr(Sen + Sen2, 64, 18));
        TextOut(0, LCD_LINE7, SubStr(Sen + Sen2, 80, 18));
        TextOut(0, LCD_LINE8, SubStr(Sen + Sen2, 96, 18));
          int Bksp = StrLen(Sen);
          if (Bksp > 0)
            Bksp--;
            Sen = SubStr(Sen, 0, Bksp);
            goto MainMenu;
        Wait(20);
      Sen = Sen + Sen2;
          TextOut(0, LCD_LINE3, "> Next", true);
          TextOut(0, LCD_LINE4, "  Done");
          TextOut(0, LCD_LINE3, "  Next", true);
          TextOut(0, LCD_LINE4, "> Done");
          if (0 == LinkNumber)
        Wait(15);
        S = true;
    int Len = StrLen(Sen);
    S = false;
    N = 0;
    LinkNumber = 0;
    S = false;
    N = StrLen(Sen);
    until (SubStr(Sen, N, 1) == "." || N == 0)
      N--;
    int Se;
    if (N == 0)
      TextOut(0, LCD_LINE1, "Add Extention?", true);
      TextOut(0, LCD_LINE8, "Yes          No");
      while (0 == ButtonCount(BTNRIGHT, true) && Se == 0) {
        Se = ButtonCount(BTNLEFT, true);
          goto WF;
      if (Se == 1)
        Sen = Sen + ".txt";
    string SenS = "", SenS2 = "";
    S = false;
    N = 0;
    LinkNumber = 0;
    S = false;
    handle = 0x00;
    LinkNumber = 0;
    cnt = 0;
    int tX = 100;
    while (tX > 0)
      tX--;
      TextOut(tX, LCD_LINE2, "Type content", true);
      Wait(18);
    Wait(SEC_1);
    while (tX < 100)
      tX++;
      Wait(18);
    while (S == false){
          N--;
          N++;
        SenS2 = Alphabet[N];
        TextOut(0, LCD_LINE1, SubStr(SenS + SenS2, 0, 18), true);
        TextOut(0, LCD_LINE2, SubStr(SenS + SenS2, 16, 18));
        TextOut(0, LCD_LINE3, SubStr(SenS + SenS2, 32, 18));
        TextOut(0, LCD_LINE4, SubStr(SenS + SenS2, 48, 18));
        TextOut(0, LCD_LINE5, SubStr(SenS + SenS2, 64, 18));
        TextOut(0, LCD_LINE6, SubStr(SenS + SenS2, 80, 18));
        TextOut(0, LCD_LINE7, SubStr(SenS + SenS2, 96, 18));
        TextOut(0, LCD_LINE8, SubStr(SenS + SenS2, 112, 18));
          int Bksp = StrLen(SenS);
          if (Bksp > 0)
            Bksp--;
            SenS = SubStr(SenS, 0, Bksp);
            goto WF;
        Wait(20);
      SenS = SenS + SenS2;
        Wait(15);
        S = true;
    CreateFile(Sen, 300, handle);
    WriteString(handle, SenS, cnt);
    CloseFile(handle);
    int tX2 = 100;
    while (tX2 > 0)
      tX2--;
      TextOut(tX2, LCD_LINE2, "Complete!", true);
      Wait(18);
    Wait(SEC_1);
    while (tX2 < 100)
      tX2++;
      Wait(18);
    if (Select == 1)
      TextOut(0, LCD_LINE2, "read. Choose a");
      TextOut(0, LCD_LINE3, "file to read.");
    RF:
    bool S = false;
    byte handle = 0x00;
    ListFilesType args;
    args.Pattern = "*.*";
    SysListFiles(args);
    int i = 0;
    if (args.Result == NO_ERR && ArrayLen(args.FileList) > 0)
      while (0 == ButtonCount(BTNCENTER, true))
        if (ButtonCount(BTNLEFT, true) && 0 < i)
          i--;
        if (ButtonCount(BTNRIGHT, true) && ArrayLen(args.FileList) - 1 > i)
          i++;
        TextOut(0, LCD_LINE3, SubStr(args.FileList[i], 0, 18), true);
        TextOut(0, LCD_LINE4, SubStr(args.FileList[i], 16, 18));
        TextOut(0, LCD_LINE5, SubStr(args.FileList[i], 32, 18));
        TextOut(0, LCD_LINE6, SubStr(args.FileList[i], 48, 18));
        TextOut(0, LCD_LINE1, "Choose File:");
           goto MainMenu;
        Wait(50);
      goto MainMenu;
    string Name = args.FileList[i];
    Sen = Name;
    string V = "";
    int B = 300;
    if(OpenFileRead(Sen,B,handle) == LDR_SUCCESS)
      ReadLnString(handle,V);
      CloseFile(handle);
      S = false;
      N = 0;
      LinkNumber = 0;
      S = false;
      N = StrLen(Sen);
        N--;
      string Str;
      Str = SubStr(Sen, N, Len);
      TextOut(0, LCD_LINE1, "Chars Count:", true);
      NumOut(0, LCD_LINE2, StrLen(V));
      TextOut(0, LCD_LINE4, "File Name:");
      TextOut(0, LCD_LINE5, SubStr(Sen, 0, N));
      TextOut(0, LCD_LINE6, "Ext: " + Str);
      Wait(SEC_2);
      int TextWrap = 0;
        if (ButtonCount(BTNLEFT, true) && TextWrap > 0)
          TextWrap = TextWrap - 100;
        if (ButtonCount(BTNRIGHT, true) && TextWrap < StrLen(V) - 99)
          TextWrap = TextWrap + 100;
        TextOut(0, LCD_LINE1, SubStr(V, TextWrap, 18), true);
        TextOut(0, LCD_LINE2, SubStr(V, TextWrap + 16, 18));
        TextOut(0, LCD_LINE3, SubStr(V, TextWrap + 32, 18));
        TextOut(0, LCD_LINE4, SubStr(V, TextWrap + 48, 18));
        TextOut(0, LCD_LINE5, SubStr(V, TextWrap + 64, 18));
        TextOut(0, LCD_LINE6, SubStr(V, TextWrap + 80, 18));
        TextOut(0, LCD_LINE7, SubStr(V, TextWrap + 96, 18));
        TextOut(0, LCD_LINE8, SubStr(V, TextWrap + 112, 18));
          goto RF;
        Wait(50);
  if (2 == LinkNumber)
    if (Select == 1)
      TextOut(0, LCD_LINE2, "Delete. Choose a");
      TextOut(0, LCD_LINE3, "file to delete.");
    DF:
    bool S = false;
    byte handle = 0x00;
    ListFilesType args;
    SysListFiles(args);
    int i = 0;
          i--;
          i++;
          goto MainMenu;
        Wait(50);
      goto MainMenu;
    Sen = Name;
    int Select2 = 0;
    GraphicOut(0, 0, "AreYouSure.ric", true);
    while (0 == ButtonCount(BTNRIGHT, true) && 0 == Select2)
      Select2 = ButtonCount(BTNLEFT, true);
        goto DF;
    int tX = 100;
    if (1 == Select2) {
      DeleteFile(Sen);
      while (tX > 0)
        tX--;
        TextOut(tX, LCD_LINE2, "Complete!", true);
        Wait(18);
      Wait(SEC_1);
      while (tX < 100)
        tX++;
        Wait(18);
    if (0 == Select2) {
      while (tX > 0)
        tX--;
        TextOut(tX, LCD_LINE2, "Canceled!", true);
        Wait(18);
      Wait(SEC_1);
      while (tX < 100)
        tX++;
        Wait(18);
    if (Select == 1)
      TextOut(0, LCD_LINE2, "Rename. Choose a");
      TextOut(0, LCD_LINE3, "file to rename.");
      TextOut(0, LCD_LINE3, "Then, type in");
      TextOut(0, LCD_LINE3, "a new filename.");
    CF:
    int N = 0, cnt = 0;
    LinkNumber = 0;
    ListFilesType args;
    SysListFiles(args);
    int i = 0;
          i--;
          i++;
           goto MainMenu;
        Wait(50);
      goto MainMenu;
    bool S = false;
    byte handle = 0x00;
    while (S == false){
          N--;
          N++;
        Sen2 = Alphabet[N];
        TextOut(0, LCD_LINE1, "New Name:", true);
          goto CF;
        Wait(20);
      Sen = Sen + Sen2;
        Wait(15);
        S = true;
    rename(Name, Sen);
  goto MainMenu;
Re: TextEdit
dudmaster wrote:So, how do i do this? (Add multiple line support)
I read multiple lines with the ReadLnString command, I just do it multiple times (as many times as there are lines). To write multiple lines, I use the WriteLnString command (again, as many times as I want lines). I am not exactly sure how that would be added to your program, but that is what I do to read and write multiple lines.
dudmaster
Re: TextEdit
Post by dudmaster »
I need to find out how many lines are in this text. How do i do that? :oops:
Re: TextEdit
For what little I have done, I did something like the following.
if(OpenFileRead("File.txt", size, handle) == NO_ERR)
  until (Sdone == true)  // read the text file till the end
    if(ReadLnString(handle,message) != NO_ERR) Sdone = true;
    //You need to grab the message and write it to another string(or whatever you need to do) all right here.
    //Base it on an increasing variable, like the following lines.
    TotalMessage[i]=message;
    i++
I hope you can get something out of that.
Re: TextEdit
Post by hassenplug »
Here's something you may find interesting. Often, when I'm doing something like this, I'll create a single image to represent the whole screen, and pass it parameters for values that will change.
Here's what I mean. I created a "main menu" graphic (attached). Pass it three parameters which represent the three menu items you want to show.
Hopefully, this code shows enough for you to understand what I mean...
int Params[] = {0,0,0};
... later in program
    Params[0] = value1;
    Params[1] = value2;
    Params[2] = value3;
    GraphicOutEx(0,0, "TextMain.ric", Params, 0);
Values...
  • 1 Open (read)
    2 Write
    3 Delete
    4 Rename
    5 Options
    0 = no item
This eliminates the need for six of your graphics.
Does that make sense?
TextMain.zip
(444 Bytes) Downloaded 1119 times
Re: TextEdit
mattallen37 wrote:For what little I have done, I did something like the following.
    i++
This is my version. The problem with Matt's code is that TotalMessage[] can suffer a STACKOVERFLOW [Beethoven's Symphony No. 5 :twisted: ].
Also, you forgot to add a `;` after the `i++`.
*I really wish we could turn `` into code snippets...
