RAW to percentage/temperature
Re: RAW to percentage/temperature
Where is it? I would like to see it, even though I don't know if I will get much from it.
You can download it from the Lego Mindstorms site...
http://mindstorms.lego.com/en-us/suppor ... x#Firmware
If you want to explore it make sure you use a good ide with good search tools to let you follow the code around (something like NetBeans or Eclipse, or if you are a command line sort of guy make sure you have grep etc. available)...
Sorry, wrong link. The correct one is here...
http://mindstorms.lego.com/en-us/suppor ... x#Advanced
scroll the horizontal scrolling thing until you can choose "open source firmware" and download that!
Here's the important bit (from the enhanced NBC/NXC firmware which is slightly different than the standard firmware):
The TempConvTable is here:
else if (sType == TEMPERATURE)
if (InputVal < 290)
InputVal = 290;
else if (InputVal > 928)
InputVal = 928;
InputVal = TempConvTable[(InputVal) - /*197*/ 290];
InputVal = InputVal + 200;
InputVal = (UWORD)(((SLONG)InputVal * (SLONG)1023)/(SLONG)900);
const SWORD TempConvTable[] =
/* 1500, 1460, 1430, 1400, 1380, 1360, 1330, 1310, 1290, 1270, 1250, 1230, 1220, 1200, 1190, 1170,
1160, 1150, 1140, 1130, 1110, 1100, 1090, 1080, 1070, 1060, 1050, 1040, 1030, 1020, 1010, 1000,
994, 988, 982, 974, 968, 960, 954, 946, 940, 932, 926, 918, 912, 906, 900, 894,
890, 884, 878, 874, 868, 864, 858, 854, 848, 844, 838, 832, 828, 822, 816, 812,
808, 802, 798, 794, 790, 786, 782, 780, 776, 772, 768, 764, 762, 758, 754, 750,
748, 744, 740, 736, 732, 730, 726, 722, 718, 716, 712, 708, 704,*/ 700, 696, 694,
690, 688, 684, 682, 678, 674, 672, 668, 666, 662, 660, 656, 654, 650, 648, 644,
642, 640, 638, 634, 632, 630, 628, 624, 622, 620, 616, 614, 612, 610, 608, 604,
602, 600, 598, 596, 592, 590, 588, 586, 584, 582, 580, 578, 576, 574, 572, 570,
568, 564, 562, 560, 558, 556, 554, 552, 550, 548, 546, 544, 542, 540, 538, 536,
534, 532, 530, 528, 526, 524, 522, 520, 518, 516, 514, 512, 510, 508, 508, 506,
504, 502, 500, 498, 496, 494, 494, 492, 490, 488, 486, 486, 484, 482, 480, 478,
476, 476, 474, 472, 470, 468, 468, 466, 464, 462, 460, 458, 458, 456, 454, 452,
450, 448, 448, 446, 444, 442, 442, 440, 438, 436, 436, 434, 432, 432, 430, 428,
426, 426, 424, 422, 420, 420, 418, 416, 416, 414, 412, 410, 408, 408, 406, 404,
404, 402, 400, 398, 398, 396, 394, 394, 392, 390, 390, 388, 386, 386, 384, 382,
382, 380, 378, 378, 376, 374, 374, 372, 370, 370, 368, 366, 366, 364, 362, 362,
360, 358, 358, 356, 354, 354, 352, 350, 350, 348, 348, 346, 344, 344, 342, 340,
340, 338, 338, 336, 334, 334, 332, 332, 330, 328, 328, 326, 326, 324, 322, 322,
320, 320, 318, 316, 316, 314, 314, 312, 310, 310, 308, 308, 306, 304, 304, 302,
300, 300, 298, 298, 296, 296, 294, 292, 292, 290, 290, 288, 286, 286, 284, 284,
282, 282, 280, 280, 278, 278, 276, 274, 274, 272, 272, 270, 270, 268, 268, 266,
264, 264, 262, 262, 260, 260, 258, 258, 256, 254, 254, 252, 252, 250, 250, 248,
248, 246, 244, 244, 242, 240, 240, 240, 238, 238, 236, 236, 234, 234, 232, 230,
230, 228, 228, 226, 226, 224, 224, 222, 220, 220, 218, 218, 216, 216, 214, 214,
212, 212, 210, 210, 208, 208, 206, 204, 204, 202, 202, 200, 200, 198, 198, 196,
196, 194, 194, 192, 190, 190, 188, 188, 186, 186, 184, 184, 182, 182, 180, 180,
178, 178, 176, 176, 174, 174, 172, 172, 170, 170, 168, 168, 166, 166, 164, 164,
162, 162, 160, 160, 158, 156, 156, 154, 154, 152, 152, 150, 150, 148, 148, 146,
146, 144, 144, 142, 142, 140, 140, 138, 136, 136, 136, 134, 134, 132, 130, 130,
128, 128, 126, 126, 124, 124, 122, 122, 120, 120, 118, 118, 116, 116, 114, 114,
112, 110, 110, 108, 108, 106, 106, 104, 104, 102, 102, 100, 100, 98, 98, 96,
94, 94, 92, 92, 90, 90, 88, 88, 86, 86, 84, 82, 82, 80, 80, 78,
78, 76, 76, 74, 74, 72, 72, 70, 70, 68, 68, 66, 66, 64, 62, 62,
60, 60, 58, 56, 56, 54, 54, 52, 52, 50, 50, 48, 48, 46, 46, 44,
44, 42, 40, 40, 38, 38, 36, 34, 34, 32, 32, 30, 30, 28, 28, 26,
24, 24, 22, 22, 20, 20, 18, 16, 16, 14, 14, 12, 12, 10, 10, 8,
6, 6, 4, 2, 2, 0, 0, -2, -4, -4, -6, -6, -8, -10, -10, -12,
-12, -14, -16, - 16, -18, -20, -20, -22, -22, -24, -26, -26, -28, -30, -30, -32,
-34, -34, -36, -36, -38, -40, -40, -42, -42, -44, -46, -46, -48, -50, -50, -52,
-54, -54, -56, -58, -58, -60, -60, -62, -64, -66, -66, -68, -70, -70, -72, -74,
-76, -76, -78, -80, -80, -82, -84, -86, -86, -88, -90, -90, -92, -94, -94, -96,
-98, -98, -100, -102, -104, -106, -106, -108, -110, -112, -114, -114, -116, -118, -120, -120,
-122, -124, -126, -128, -130, -130, -132, -134, -136, -138, -140, -142, -144, -146, -146, -148,
-150, -152, -154, -156, -158, -160, -162, -164, -166, -166, -168, -170, -172, -174, -176, -178,
-180, -182, -184, -186, -188, -190, -192, -194, -196, -196, -198, -200/*,-202, -204, -206, -208,
-210, -212, -214, -216, -218, -220, -224, -226, -228, -230, -232, -234, -236, -238, -242, -246,
-248, -250, -254, -256, -260, -262, -264, -268, -270, -274, -276, -278, -282, -284, -286, -290,
-292, -296, -298, -300, -306, -308, -312, -316, -320, -324, -326, -330, -334, -338, -342, -344,
-348, -354, -358, -362, -366, -370, -376, -380, -384, -388, -394, -398, -404, -410, -416, -420,
-428, -432, -440, -446, -450, -460, -468, -476, -484, -492, -500, -510, -524, -534, -546, -560,
-572, -588, -600, -630, -656, -684, -720, -770 */
Ok, thank you. Hopefully I will be able to learn from it.
I hate to bump up old posts but I found something rather interesting that I thought you might want to know. While reading the Spanish Wikipedia entry for Lego Mindstorms (which, IMHO is way better than the numerous English entries) I came across a simple equation that supposedly calculates the temperature from the raw value. Keep in mind that I haven't tested this, the main reason being that I don't have a Legacy Temp sensor. I also remember finding an equation for raw-to-temp in the Extreme NXT book (second edition) but for some reason didn't bookmark it...
-Edit- Post 100!
-Edit- Post 100!
The formula is on page 80 of the book.
Or, page 82 in the second edition. Ok, I thought that equation was to calculate which thermistor would be best as far as similarity to the Legacy sensor. I thought I'd found a different, simpler, equation elsewhere in the book, I must be mistaken
Thanks, I'll be sure to try it out. Just so you don't have to go looking, here are the formulas according to that page.
Edited for accuracy.
Light = 146 − RAW / 7
Temp = (785 − RAW) / 8
if (RAW>450) //touch = 1
I think that when you copied the Light equation over you might have missed some of it
. Complete version below.
-EDIT- Now I messed up! Copied over the Temperature equation instead of the Light equation
Light = 146 − RAW / 7One King to rule them all, One King to find them,
