Use a Wii Motion Plus, using I2C interface ?
hergipotter
Re: Use a Wii Motion Plus, using I2C interface ?
oh good lord, i first have to find my magnifying glass for this...
hergipotter
Ok, i'm much to unexperienced with such things...
I can't follow a trace to a resistor at all.
Seems like there isn't a trace from the CLK pin at all?! Or is it within another layer?
it seem not easy ...
Mybe with a multimeter it could be possible to find the connections.
hergipotter
I already searched with my multimeter but no resistor seems to be directly connected with on of the three pins...
Perhaps the pull-ups are integrated in the µC?
That picture isn't clear enough. Try looking for two resistors that have the same values as each other, and are probably fairly close on the PCB. You are probably looking for something like 4k7 or 10k (maybe 2k2). The actual value isn't all that important, but it should be something like that.
Another option, you could try it with the existing resistors. It won't damage the NXT, as it has 4k7 protection resistors. It almost definitely won't work, but it is worth a try. nxtreme has had success using 10k with a compass, so you never know.
I happen to have an NXT-PICAXE project right in front of me. It is a simple setup, where the PICAXE (20X2) is an I2C slave, and the NXT is the master. I have the NXT reading values from it (it's ADC values). I just swapped out the pullups, to see when I stopped getting good readings. It worked up to 10k, but any stronger (even a 100k in parallel with the 10k), and it failed (on the clock line, but not data). I increased resistance to 1m, and it didn't work, so I tried 470k, and it works fine. It appears that the NXT is okay with anything in the 10k-470k ohm resistor range, but that was with a 20X2, other ICs might not be able to go to these limits.
That is possible, some u-controllers do integrate them, but usually the designer can turn them off. I think the PICAXE 20X2's have an option to have pullups internally on their I2C lines, but I have never looked into it.hergipotter wrote:...Perhaps the pull-ups are integrated in the µC?
hergipotter
Little Update:
I recently realised, that the cables on the motion plus have very different colors than with the nunchuk.
VCC - grey
SCL - red
SDA - green
GND - blue/black
But that doesn't change much, i still could not find the pull ups. But i found two resistors, that are close and have values of 10k, when tested in circuit (My multimeter tests the resistance between the two connectors of the resistor, that does not need to be the actual resistance value of the resistor). They're R13 and R4 on the other side of the pcb. R4 is connected with VCC on one side, but i could not find a connection to CLK or DATA on the other side. On the other hand R13 is connected to GND on one side. I'm not really sure what that means...
So i just tried to read the sensors without changing the resistors but it won't work.
I hope my code is correct.
It just prints the number of bytes that were read but it always prints 0...
VCC - grey
SCL - red
SDA - green
GND - blue/black
#define PORT S4
#define LOOPS 1
byte WMplusActivate[] = {0xA6, 0xFE, 0x04};
byte WMplusWrite[] = {0xA4, 0x00};
byte WMplusRead[] = {0xA4};
byte nbytes;
byte data[];
void initWMplus()
LowspeedWrite(PORT, 0, WMplusActivate);
while(LowspeedStatus(PORT, nbytes)>0);
void readWMplus()
LowspeedWrite(PORT, 0, WMplusWrite);
LowspeedWrite(PORT, 6, WMplusRead); //ask for 6 bytes
NumOut(15, LCD_LINE6, nbytes); // Print number of bytes read
if(nbytes == 6){
LowspeedRead(PORT, 6, data) //read data from buffer
for(int i=0; i<6; i++ ){
data[i]=(data[i]^0x17) + 0x17; // decode data
else {
ArrayInit(data,0,0); //error
SetSensorLowspeed(PORT);
initWMplus();
for (int j = 0; j < LOOPS; j++)
readWMplus();
/*if (ArrayLen(data)==6) {
for(int i=0; i<ArrayLen(data); i++ ) {
TextOut(15*i, LCD_LINE5, FormatNum("%02X", data[i])); //hex: enhanced firmware
//NumOut(15*i, LCD_LINE5, data[i]); //dez: lego firmware
Wait(100);
Wait(3000);
}link to my youtube channel under my avatar!
hergipotter
Finally a success!!
It seems, that there are no pull ups on the WMP at all. So i just put two 27k ones in there and it worked. Additionally i added two 1N 4148 diodes to lower the supply voltage. The NXT gives about 4.5V but the WMP normally works with 3.3V. Maybe it would also work with only one or no diode at all...
Some pictures and my testprogramm:
#define PORT S4
#define SHOW_CALIB_VALUES
byte nbytes;
byte data[];
int yaw, pitch, roll; // variables holding sensor values
int yaw0, pitch0, roll0; // variables for offset values
/* Initialises the Wii Motion Plus.
After this, the i2c address changes to 0xA4
void initWMplus()
/* Calibrates the offset values by
computing the average of ten readings
void calibrateOffset()
int i = 0;
while (i < 10) // read sensors 10 times
if(nbytes == 6)
LowspeedRead(PORT, 6, data); //read data from buffer
yaw0 += (((data[3]>>2)<<8) | data[0]) / 10;
pitch0 += (((data[4]>>2)<<8) | data[1]) / 10;
roll0 += (((data[5]>>2)<<8) | data[2]) / 10;
i++;
Wait(50);
#ifdef SHOW_CALIB_VALUES
NumOut(55, LCD_LINE3, yaw0);
NumOut(55, LCD_LINE4, pitch0);
NumOut(55, LCD_LINE5, roll0);
TextOut(5, LCD_LINE3, "yaw0: ");
TextOut(5, LCD_LINE4, "pitch0: ");
TextOut(5, LCD_LINE5, "roll0: ");
Wait(3000);
#endif
/* Reads the sensor values.
After this, the raw values are stored in the data array
and the computed values can be read from yaw, pitch and roll variables
void readWMplus()
if(nbytes == 6){
yaw = (((data[3]>>2)<<8) | data[0]) - yaw0;
pitch = (((data[4]>>2)<<8) | data[1]) - pitch0;
roll = (((data[5]>>2)<<8) | data[2]) - roll0;
else {
initWMplus();
Wait(300); // Wait some time after init
calibrateOffset();
while (true)
readWMplus();
TextOut(15*i, LCD_LINE1, FormatNum("%02X", data[i])); //hex: enhanced firmware
//NumOut(15*i, LCD_LINE5, outbuf[i]); //dez: lego firmware
NumOut(55, LCD_LINE3, yaw);
NumOut(55, LCD_LINE4, pitch);
NumOut(55, LCD_LINE5, roll);
TextOut(5, LCD_LINE3, "yaw: ");
TextOut(5, LCD_LINE4, "pitch: ");
TextOut(5, LCD_LINE5, "roll: ");
Wait(200);
I am glad it work. Thanks for posting your results and example.
Wow, thanks for posting this! I had a bit of a hard time finding the resistors in my (knockoff) Nunchuck too. However, I finally measured the resistance from the clock and data pins to the power pin, to figure out what size pullups were installed. Then, I searched the board for two resistors that were of that value. Just a little hint for next time
I'm hoping to eventually create a quadrotor, which would need 3x of gyros and 3x of accelerometers. It'd be especially fun to set it all up with the NXT, will have to bookmark this.
It almost looks to me like you soldered everything to the jack for the Nunchuck, not the end that goes into the WiiMote. That might be why you couldn't find any pullups, although I could be wrong
-EDIT- I just remembered that I was going to mention something else. I use 3.3V V-regs to drop the NXT's 4.5V down to 3.3V. I have only used the LP2950-33, but almost any would work just so long as you include the capacitors, which are necessary.
