NXC: "Speech"-Recognition
Re: NXC: "Speech"-"Recognition"
German Aczent Guy wrote:Aczent?
What iz zis "aczent"?
I doez not know. But I doez thinkz that thiz is a very "cool" demo az the Americanz zayz zo, no? Ja, zhis iz very cool. (I learned German from Madame Stellenbosch, and some "genius" in "Maximum Ride: Saving the World and Other Extreme Sports" and another one in Maximum Ride books 5 to unknown.)
Format (I haven't even looked at your code ;) ):
0 - 3 Bytes: Number of words
4 - 7 Bytes: Number of samples (in first word)
8 - 11 Bytes: Number of bytes of data
12 - x Bytes: RAW MEAT -- er... -- data
zoltanszalontay
Post by zoltanszalontay »
Hi there, I am a newbie to NXT. For me, NCX fails to compile with "Undefined Identifier getchar". Do I need to include any header files to compile? BRICX is set NOT to ignore system include files in NXC config.
Any help would be appreciated. Thanks, Z
Are you sure that you have the latest EFW and the latest Bricxcc 3.3.8.9 built 2010-11-03 ?
zoltanszalontay
Bingo! The fw made the trick. Thanks, Z
Re: NXC: "Speech"-Recognition
new version: at every new start the Language Center containing the trained words will be reloaded!
Share and Enjoy! ;)
// "speech" recognition
/**/ string version="1.07";
// programming language: NXC for Mindstorms NXT
// author: HaWe 2011
// speak, and watch the real-time oscillograph.
// as soon as the oscillograph appears you may press BtnCenter to store.
// choose the slot to store by <<BtnLeft or  >>BtnRight
// press BtnCenter again to store, or press BtnExit to delete the pattern
// io functions
  TextOut(_x, _y, sval1); \
char LCDline[]={56,48,40,32,24,16,8,0};
inline bool btnhit(){
   return ( ButtonPressed(BTN1, false) || ButtonPressed(BTN2, false)
         || ButtonPressed(BTN3, false) || ButtonPressed(BTN4, false));
inline int cin() {
  int result = -1;
    if (ButtonPressed(BTN1, false))
      result = BTN1;
    else if (ButtonPressed(BTN2, false))
      result = BTN2;
    else if (ButtonPressed(BTN3, false))
      result = BTN3;
    else if (ButtonPressed(BTN4, false))
      result = BTN4;
    return result;
#define MinPause  80
#define dbOffset  30
#define RecLen   128
#define RecSlots  16
int  BGrndNoise=50, dbMax;
int  SoundRecord[RecLen];             // detection: 0...RecLen:
int  SoundPattern[RecSlots][RecLen];  // patterns
char key;
// File I/O
inline void SoundExport() { // Data Export format: number-strings, seperated by ";"
  string sFileName = "FILE_EXP.dat";
  unsigned int nFileSize = (RecLen*4); //3 byte for number (text) plus 1 (";") each
  byte fHandle;
  int IOresult, counter=0;
  int ibuf, i;
  string s;
  TextOut( 0,48, "SpeechRecogn "+version);
  DeleteFile(sFileName);
  IOresult = CreateFile(sFileName, nFileSize, fHandle);
  if (IOresult == LDR_SUCCESS) {
    for (i=0; i<RecLen; i++)   {
        counter+=1;
        ibuf= SoundRecord[i];
        printf1( 0, 32, "counter =%5d", counter);
        printf1( 0, 24, "loudness=%5d", ibuf);
        s=NumToStr(ibuf);
        s=s + ";" ;
        fputs(s, fHandle);
    CloseFile(fHandle);
    printf1( 0,16, "%s", "! FILE STORED !");
  else  {
    printf1( 0,16, "%s", "Error-Save-Error");
    Wait(1000);
void WordSave(byte slot, bool saveIt) {
  string s, sFileName;
  unsigned int nFileSize = (RecLen*4); // integer (2) + CR (1) + LF (1) bytes
  byte fHandle;
  int ibuf, i;
  s=FormatNum("%04d", slot);
  sFileName=StrCat(s, ".wpt");
  if (saveIt==FALSE) return;
        counter+=1;
        ibuf= SoundPattern[0][i];
        printf1( 0, 24, "counter =%5d", counter);
        printf1( 0, 16, "loudness=%5d", ibuf);
        WriteLn(fHandle, ibuf);
    CloseFile(fHandle);
  else  {
    Wait(1000);
void LoadLanguageCenter() {
  string sFileName;
  unsigned int nFileSize;
  byte fHandle;
  int IOresult;
  int ibuf, i, j=0, slot;
  string s;
  ListFilesType SearchRec;
  SearchRec.Pattern = "*.wpt";
  SysListFiles(SearchRec);
  while (SearchRec.Result == NO_ERR && j < ArrayLen(SearchRec.FileList))
    sFileName=SearchRec.FileList[j];
    TextOut(0, LCDline[0], sFileName);
    s=SubStr(sFileName, 0, 4);
    slot=StrToNum(s);
    printf1( 0, LCDline[1], "slot=%3d", slot);
    IOresult = OpenFileRead(sFileName, nFileSize, fHandle);
        ReadLn (fHandle, ibuf);
        SoundPattern[slot][i]=ibuf;
        printf1( 0, LCDline[2], "counter =%5d", i);
        printf1( 0, LCDline[3], "loudness=%5d", ibuf);
      CloseFile(fHandle);
      printf1( 0, LCDline[7], "FILE%3d RELOADED!", slot);
    else {
      printf1( 0, LCDline[7], "! ERROR ! FILE%3d", slot);
      Wait(1000);
    ClearLine(LCDline[1]);
    ClearLine(LCDline[2]);
    ClearLine(LCDline[3]);
    j++;
task SoundCheck() {
  int t,       // timer counter
      p,       // pause counter
      i, j,    // index
      peak,    // for oscilligraph
      slot=1,  // slot for sound records
      j_best,  // slot which matchs best
      buf;
  long SoundLevel,
       sum[RecLen],
       sum_min,
       d2;
  string str;
  while(true) {
    str=".";
    SoundLevel=SensorValue(S2);
    printf1(0,LCDline[0], "%s", "BGrndNoise=");
    printf1(60,LCDline[0], "%4d", SoundLevel);
    Wait(4);
    //  record if min sound level reached //
    if (SoundLevel>(BGrndNoise + dbOffset)) {
      p=dbMax=0;
      t=1;
      key=-1;
      ArrayInit (SoundRecord, 0, RecLen);
      while (t<RecLen-1) {
        SoundLevel=SensorValue(S2)-BGrndNoise;
        if (SoundLevel > dbMax) dbMax=SoundLevel;
        // if observe Pause then Rec_Stop
        p= (SoundLevel<dbOffset)? p+1 : 0;
        if (p==MinPause) break;
        if (t%2==0) {
          peak=SoundLevel;
          LineOut ((t+1)/2, 0, (t+1)/2, peak/8);
        printf1(0, LCDline[0], "%s", "store: press BtnCtr" );
        if (btnhit() && key==-1) key=cin();
        //   normalize to sound level steps     //
        SoundRecord[t]=(SoundLevel*128)/dbMax;
        if (SoundLevel < BGrndNoise)
          SoundPattern[0][t]=0;
          SoundPattern[0][t]=(8*SoundRecord[t])/8;
        Wait(7);
        t++;
        if(t%25==0) str+=".";
      SoundRecord[0]=t;                  // store current recording duration
      if (t<100) Wait(200);
      for (i=t; i<RecLen; i++) {
         SoundPattern[0][i]=0;           // fill slot pattern with "0"
      SoundPattern[0][0]=SoundRecord[0]; // store current recording duration
      if (btnhit()) key=getchar();       // wait until Btn up
      // SoundExport();
      //   allow sound record to be stored    //
      if ( key == BTNCENTER ) {
         key=-1;
         printf1(0, LCDline[1], "%s", "store in slot:");
         printf1(0, LCDline[7], "%s", "<<-1 OK/del +1>>");
         while (key!=BTNEXIT && key!=BTNCENTER) {
           printf1(0, LCDline[2], "%2d", slot);
           key=getchar();
           if (key==BTNLEFT) {
             if (slot>1) slot-;
             if (slot==1) slot=RecSlots-1;
           if (key==BTNRIGHT) {
             if (slot<RecSlots-1) slot++;
             if (slot==RecSlots-1) slot=1;
           if (key==BTNCENTER) {
               SoundPattern[slot][i]=SoundPattern[0][i];
             printf1(1, LCDline[2], "stored: Slot %2d", slot );
             WordSave(slot, TRUE);
             Wait(300);
           if (key==BTNEXIT) {
               SoundPattern[slot][i]=0;
             printf1(1, LCDline[2], "deleted:Slot %2d", slot );
             WordSave(slot, FALSE);
             Wait(300);
         } // while
         key=-1;
      //  compare and recognize sound record  //
        sum_min=LONG_MAX; j_best=INT_MAX;
        str=".";
        for (j=1; j<RecSlots; j++) {
          TextOut(0, LCDline[1], str);
          sum[j]=0;
          if (SoundPattern[j][0]>10) {
            for (i=1; i < RecLen; i++) {
              d2=(SoundPattern[0][i]-SoundPattern[j][i]);
              sum[j]=sum[j] + d2*d2;
          else {
            sum[j]=LONG_MAX;
          buf=sum[j];
          if (sum[j]<sum_min) {
            sum_min=sum[j];
            j_best=j;
          str+=".";
        } // for j
        if (j_best< INT_MAX)
          printf1(0, LCDline[1], "recogn=Pattern%2d", j_best );
      } // else compare
  } // while true
} // SoundCheck
void init() {
  unsigned long sbuf;
  SetLongAbort(true);
  SetSensorType(S2, SENSOR_TYPE_SOUND_DBA);
  SetSensorMode(S2, SENSOR_MODE_RAW);
  for (int i=0; i<1000; i++) sbuf+=SensorValue(S2);
  BGrndNoise=sbuf/1000;
  init();
  LoadLanguageCenter();
  StartTask(SoundCheck);
  while (true)  {
"Share and Enjoy" is the slogan of the complaints division of the Sirius Cybernetics Corporation. The "Hitchhiker's Guide to the Galaxy" relates that the words "Share and Enjoy" were displayed in illuminated letters three miles high near the Sirius Cybernetics Complaints Department, until their weight caused them to collapse through the underground offices of many young executives. The upper half of the sign that now protrudes translates in the local tongue as "Go stick your head in a pig", and is only lit up for special celebrations.
Generally the DFT (Discrete Fourier Transformation) might have been a good appoach (running on a PC, thanks to author Christian alias xeraniad):
"Backwards" vs. "Backwards" auto correlation - it shows a symmetrical curve with 2 maxima of 1,00 at both edges = 100% correlation:
"Backwards" vs. "ExitStop" correlation - not symmetrical, almost = zero at the edges = just 0% correlation:
Results:
Using a DFT (resp. FFT =Fast Fourier Transformation)) on the NXT won't work because
1) it's too slow: already calculating and checking the REAL parts takes several minutes!
2) phase-rotated patterns ("Short-Looong" vs. "Looong-Short") can't be distinguished using just the REAL part of the vectors, and
3) if using also the IMAGINARY part it would last far too long for calculating and to find a correlation.
My next approach was a cross correlation of the original patterns as a substitute to my current "smallest sum of squared deviations" (again thanks to Christian alias xeraniad):
[latex]\mathrm{ccf}_{m}%20(f,g)%20\%20=%20\%20\frac{\sum_{n=0}^{N-m-1}f_{n+m}%20\cdot%20g_n}{\sqrt{\sum_{n=0}^{N-m-1}(f_{n+m})^2%20\%20\cdot%20\sum_{n=0}^{n-1}(g_n)^2}}[/latex]
https://bildungs-foren.de/tools/latex2p ... c23a70.png
Results:
Still far too slow! !This formula needs 100 times longer to be calculated than the method by the smallest sum of squared deviations- no chance for "real time recognition" :(
substitute and workaround so far::
new version 1.05 based on the smallest sum of squared deviations:
enhanced recognition algorithm (since 1.03) , store and delete patterns on the flash (since 1.00 / 1.01)
correctly spoken (i.e. correct pronounciation and intonation) the new version may correctly distinguish (e.g.) between the words
' Stop-' Stop
' Right
' Left
' Forward
re 'verse
'Sloow ' Doown
https://sourceforge.net/apps/phpbb/mind ... 4350#p4350
