NXT Grayscale Screen?
Re: NXT Grayscale Screen?
Ah, you're right. Thanks for correcting me on that. I have no idea why I though the ATMEGA controlled it.
If all you want to do is change the color of the whole screen you can use SetDisplayContrast() in NXC (This requires EFW 1.28+)
This is the sample program from the NXC Guide
for (byte contrast = 0; contrast < DISPLAY_CONTRAST_MAX; contrast++)
SetDisplayContrast(contrast);
NumOut(0, LCD_LINE1, DisplayContrast(),);
Wait(100);
for (byte contrast = DISPLAY_CONTRAST_MAX; contrast > 0; contrast--)
NumOut(0, LCD_LINE1, DisplayContrast());
Wait(100);
SetDisplayContrast(DISPLAY_CONTRAST_DEFAULT);
while(true);
They want actual grayscale.timpattinson wrote:If all you want to do is change the color of the whole screen you can use SetDisplayContrast() in NXC (This requires EFW 1.28+)...
Hmm... can you change this at a frequency greater than 10Hz?timpattinson wrote:If all you want to do is change the color of the whole screen you can use SetDisplayContrast() in NXC (This requires EFW 1.28+)...
If the viewer is d cm distance away from the NXT, you can try "halftones":
void GS_RectOut(int x, int y, int width, int height, unsigned long options=DRAW_OPT_NORMAL, int blockSize = 2)
for(int _y = y; _y < (y + height + 1); _y++)
for(int _x = x; _x < (x + width + 1); _x++)
PointOut(_x, _y, ((_x % blockSize) + (_y % blockSize)) % blockSize);
}Also, the changing the "options" argument won't really do anything as you would expect it to. I haven't added that functionality for sake of simplicity. I'm not sure if "blockSize" will work as I expect it to if you change it to any value other than 2... (This is just an example; I'm not going to waste brain CPU on this! ...I think Doc had the right idea: do the "hard" stuff, but not the "easy" stuff.
Will test this ... stay tunedmuntoo wrote:Hmm... can you change this at a frequency greater than 10Hz?timpattinson wrote:If all you want to do is change the color of the whole screen you can use SetDisplayContrast() in NXC (This requires EFW 1.28+)...
Have done a test with this code...
It takes 8914ms to change the contrast 32767 times (i used an int as the counter variable , this is the max of the int type)
bool max = false;
unsigned long timer = CurrentTick();
for(int i = 0; i < INT_MAX; i++)
if(max)
SetDisplayContrast(DISPLAY_CONTRAST_MAX);
max = !max;
TextOut(0,LCD_LINE1,StrCat( NumToStr(CurrentTick() - timer),"ms" ,"/", NumToStr(INT_MAX)));
while(1);
Sure, you can send the command that frequently, but does the LCD screen processor actually do anything with that changed info more than 10 times a second? It would be no different than changing the motor speeds every 1ms in your program when the ATmega only updates it every 3ms.
You were probably just using made up numbers in that motor update speed example, because IIRC, with standard FW, it is every 100ms, not 3ms (for your/others information).
The ARM7 and ATmega chat each 3ms from what I've understood. Perhaps the motor example was not a very good one, but you get what I mean
A better example would be the PELICAN crossing system. Pressing the button repeatedly to make the little man turn green isn't going to make him change any faster. That never seems to stop people, though.
So waht about using halftone and putting flashing black pixels over it?
Users browsing this forum: No registered users and 46 guests
