SpawnProgram exists but as we have discussed previously (on the nxtasy forums) it does not work quite right. The firmware gets annoyed about something when you fiddle around with the Command module IOMap in this way. I have not yet been able to come up with a method that works reliably.
NXC : Start Program command(?)
Re: NXC : Start Program command(?)
Can you post the code? I'd like to see it, reliable or not.
Thanks.
Thanks.
The code is in NXTDefs.h which you can view using the BricxCC Preferences dialog on the API tab. It is also checked into SVN on the BricxCC source forge project.
http://bricxcc.svn.sourceforge.net/svnr ... /NXTDefs.h
The code is pretty simple. It writes to the Command module IOMap.
If you look in NXCDefs.h you'll see a one line macro that wraps this NBC code. It reliable spawns the specified program but when that program aborts or exits the firmware winds up in a bad state which requires pulling a battery to fix.
#ifdef __ENHANCED_FIRMWARE
#define __spawnProgram(_fname) \
acquire __IOMWMutex \
mov __IOMWBIArgs.ModuleID, CommandModuleID \
mov __IOMWBIArgs.Offset, CommandOffsetActivateFlag \
arrsubset __IOMWFlattenBuf, _fname, NA, 20 \
arrbuild __IOMWBIArgs.Buffer, 1, 0, __IOMWFlattenBuf \
syscall IOMapWriteByID, __IOMWBIArgs \
release __IOMWMutex \
stop NA
#else
mov __IOMWArgs.ModuleName, CommandModuleName \
mov __IOMWArgs.Offset, CommandOffsetActivateFlag \
arrbuild __IOMWArgs.Buffer, 1, 0, __IOMWFlattenBuf \
syscall IOMapWrite, __IOMWArgs \
stop NA
#endif
