Need help with PCF8574
brandts
Re: Need help with PCF8574
Post by brandts »
> philoo
That's not a stupid question because I think more people make this mistake.
In the attachment I numbered the pins how I think they should be.
> h-g-t
As mentioned above I tried both address but they both don't work. After that I did connect the chip to a motor port to see if any of the led wen't on or off but that didn't make a different. It might be possible that I damaged the chip by doing that.
> mattallen37
Thanks for your code. I'm going to try it tonight. If this won't work I think I'm going to start all over again with a new chip :(
Also, you should check to be sure you used the proper pullups. Lego uses 82k, but I have successfully used down to 10k, and up to 470k.
