BBCode Wishlist
Re: BBCode Wishlist
I can probably host that script on the project's website. Some options will not be available, due to the fact that certain conversion utilities are just not present on those systems.
Re: BBCode Wishlist
I already added sebi's script on our experimental Mindstormsforum (phpBB3) but it doesn't work so far:
http://www.mindstormsforum.com/viewtopi ... 4&p=48#p48
<img> is probably not supported by phpBB3 - how can you activate it?
Re: BBCode Wishlist
Just copy the formula into this URL: http://mindboards.sourceforge.net/latex2png.php and put img tags around the resulting png.
Re: BBCode Wishlist
don't know how you mean it - doesn't work for me
Re: BBCode Wishlist
I edited your message, take a look at it now.doc-helmut wrote:don't know how you mean it - doesn't work for me
Re: BBCode Wishlist
ok, I see it.
But it's far more complicated than the <img> script or the
BBcode for it.
can't you get sebi's macro working?
Re: BBCode Wishlist
No, I don't really have the time for that. This works and it's not that complicated. If you can write LaTex, you can manage a simple [img] tag.
If you want it to work with the math tags, I suggest you make it work and give me instructions on how to add it to the boards.
Re: BBCode Wishlist
we installed sebi's code in the admin control panel of our experimental forum and it works!
http://www.mindstormsforum.com/viewtopi ... 8&p=48#p48
admin control panel -> posting
-> BBCode usage
-> HTML replacement
maybe try your own link instead:
-> Help line text
test:
-> BBCode usage
[math]{TEXT}[/math]Code: Select all
<img src="http://www.matheboard.de/latex2png/latex2png.php?{TEXT}" alt="Formel">Code: Select all
<img src="http://mindboards.sourceforge.net/latex2png.php?{TEXT}" alt="Formel">-> Help line text
replace {TEXT} e.g. by sum_{i=1}^k%20p_i%20Code: Select all
[math]sum_{i=1}^k%20p_i%20[/math]Re: BBCode Wishlist
Did Sebastian modify his script? It's not working for me.
