wishlist for NXC
Re: wishlist for NXC
I'm inclined to leave things as they are in NXC wrt uninitialized local variables.
it seems to be initialized to 0 though:
void testFunction() {
  static int i;
  ++i;
  NumOut(0,0,i);
task main() {
  testFunction(); // ...
  testFunction(); // prints 3
  while(1);
after restarting this program several times, it always shows "3" . So "static i" seems to be initialized to 0 for every new run.
CMIIW, but if not re-initialized to 0 it should keep the last value in memory after program abort and should increase i by 3 in the end for every new program run (that's what C is supposed to do ... or not?)
AFAIK, it is not possible to not initialize variables to something at program start. It must either be a user-defined value or NULL. Uninitialized variables in NXC will therefore be initiated to NULL.
I haven't read the C specification but I would imagine it says that the behavior of uninitialized variables are undefined. Does anyone know? (To be honest I actually don't really care that much about how NXC handles this or how it is supposed to behave in C...)
well, I don't care either, I just want to know - and John's post in this context
as I understand it, there actually are things like uninitialized local variables
though but my program example shows, that there aren't
Read.
Standards.
We're getting OT...
muntoo, you misunderstand me.
I didn't want to know what C does,
I wanted to know what Johnt meant saying "leaving... uninitialized local variables"
doc-helmut wrote:I wanted to know what Johnt meant saying "leaving... uninitialized local variables"
It means John wants:
task main() {
    int x;
    printf("%d", x); // prints 0
He doesn't want:
    printf("%d", x); // prints 15394 (i.e. garbage)
Or:
    printf("%d", x); // CRASH!
Same applies to all other ways to declare x: globally, etc. (I don't know about arrays, but I presume that it'll set everything to 0.)
thx, now I understand.
(Before it was incomprehensible to me.)
All I meant was that I would not change NXC to explicitly initialize local variables that lack a user-specified initial value to zero at runtime. As has been pointed out, all along NXC has been generating variable declarations for variables that you do not explicitly initialize in your code in a manner that initializes them to zero when the RXE begins execution. I will leave this unchanged.
nxtboyiii
Post by nxtboyiii »
I would like to have a function to rotate an ric file.
I would also like to be able to rotate polygons. Like this:
void RotatePoly(LocationType &points[], int degrees)
//Rotate it
nxtboyiii wrote:I would like to have a function to rotate an ric file.
Or the ability to efficiently read/write to the display screen memory. (We could apply our own transforms by developing our own libraries.)
The rotate polygons should be easy enough, though - I suggest you create a separate thread.
