If you can put in stuff like "NXTScreen"/"Watch"/and other tools in a Tools menu, or something... And organize the menus better than BricxCC, which don't seem as "logical" as I should like.
*No offense, John.
The actual text editor is one thing. The tabs (for indenting code) are kind of messed up, and it's not too beautiful. The drag & copy is also messed up. These are only two of the multiple reasons why I've switched to Notepad++.mattallen37 wrote:I actually like BCC a lot more than the Arduino or PICAXE IDE. It is really easy to use IMO. I can't think of anything at the moment that I would prefer to have different, other than perhaps some of the RCX vs. NXT terms fixed a little.
This is theoretically possible, especially since I plan to implement a "custom code" block that lets you inject straight-up NXC code right into your program. I don't want to steal BricxCC's glory though.. it's an incredible achievement/investment, and John has put a lot of work into it. V-NXC is meant to supplement BricxCC, not to replace it. Users will likely still be required to install BricxCC in order to compile and etc.muntoo wrote:I'm starting to think that this can actually be an alternate IDE than BricxCC - and not just for the Visual NXC users, but for the "text" NXC users too. BricxCC's GUI isn't too impressive (IMHO), but not every programmer's a designer*.
*No offense, John....Unless you really consider yourself to be an artist.
YAY! Finally! A NXT language that works on Ubuntu! THANK YOU!!sidneys1 wrote:Just a quick update.. I downloaded the Mono plugins for VS2010, and so far it looks like Visual NXC is 100% Mono compatable, so hopefully when I'm done Linux and Mac OSX users will be able to use it as well
Have a nice day,
~Sidneys1
EDIT: And here's a screenshot of it running on MONO! Maybe I'll see what it looks like on Ubuntu laterBecause of certain limitations of Mono, I had to tweak the Aero Glass extentions around, and as a result their slightly off-kilter, but I can fix that with some more "#if MONO" code.... Also, the icons for Threads and Methods in the "Items:" view seem to have gotten stretched somehow..
Unfortunately, Mono doesn't officially support Ubuntu.. I just found that outjojoguy14 wrote:
sidneys1 wrote:Unfortunately, Mono doesn't officially support Ubuntu.. I just found that outjojoguy14 wrote:
Have a nice day,
~Sidneys1
Sorry to butt into this thread with this, but I keep getting a 'frog in an icecube' image with some text which states "domain unregistered" with your images. When I go to the site, it said that the site admin/moderator must register the site to access images?sidneys1 wrote:Did some scrummaging around, and here's what I've done. The Mono V-NXC (left) and the .NET V-NXC (right) are now almost identical! I solved the issue with the method and thread icons by dumbing them down from 32-bit color depth to 8-bit color depth. The rest was all issues with metrics.. I didn't even need #if MONO!
Have a nice day,
~Sidneys1
Users browsing this forum: No registered users and 27 guests
