MindBOARDS NXT-G Block Repository
bungeshea
Guide to Importing & Exporting blocks
Post by bungeshea »
Just in case anyone was interested I have posted a quick guide here about importing and exporting NXT-G blocks.
http://nxtguide.yolasite.com/managing-blocks.php
I will update it with images and more info when I have time. If the link doesn't work you can acsess it from the base site at
http://thenxtgeneration.webs.com/ or http://nxtguide.yolasite.com/
:D
jojoguy14
Re: MindBOARDS NXT-G Block Repository
Post by jojoguy14 »
What other blocks do we need? I have a BUNCH on my flash drive, so I can upload them here.
Known as jojoguy10
bungeshea
Post by bungeshea »
jojoguy14 wrote:What other blocks do we need? I have a BUNCH on my flash drive, so I can upload them here.
If you check out the MindBOARDS Repository and navigate to Main Repository/NXT-G Blocks that is a complete list of the ones we have. I know we are missing the Array Block, the Average block, the Memory Level block and the Music Box block.
jojoguy14
Post by jojoguy14 »
OK, I found the Memory Level block, Array block, and Average block! YAY! I don't have the music box (I don't think) :-(
Array Block.zip
(181.25 KiB) Downloaded 948 times
Average Block.zip
(63.54 KiB) Downloaded 965 times
Memery Level Block.zip
(107.47 KiB) Downloaded 969 times
Known as jojoguy10
I have had a look through my computer and found the following files which all appear to have been created using RobotC so I presume they are NXT-G blocks.
Bit Logic.zip
(76.72 KiB) Downloaded 1046 times
DisplayNumber.zip
(93.41 KiB) Downloaded 1100 times
IIC Read Multiple.zip
(200.9 KiB) Downloaded 1010 times
And 3 more :-
IIC_Read.zip
(146.67 KiB) Downloaded 1039 times
IIC_Write.zip
(150.62 KiB) Downloaded 1010 times
Mask.zip
(61.18 KiB) Downloaded 1052 times
And finally :-
NXTMMX.zip
(542.29 KiB) Downloaded 1053 times
PCF8591-NX.zip
(342.42 KiB) Downloaded 999 times
PCF8574-NX.zip
(176.65 KiB) Downloaded 1053 times
bungeshea
Post by bungeshea »
jojoguy14 wrote:OK, I found the Memory Level block, Array block, and Average block! YAY! I don't have the music box (I don't think) :-(
Gee, thanks. I have been looking for these blocks for AGES! :P People keep forting rbts that use the block, but as I have said, these will not work. We do already have the blocks from Team Hassenplug though. (That was the second place I found, the first being the MINDSTORMS Support Section. Also, there is a whole heap of stuff at the LEGO Education Site, including the Dynamic Block Update, Colour Lamp & Colour Sensor blocks and the RCX Legacy Blocks.
More blocks excavated from the dark depths of my hard drive. Some of these may have the same names as files in the repository but I do not know if they are exactly the same blocks; I have come across duplicate names for different blocks in the past.
atan_block.zip
(70.88 KiB) Downloaded 921 times
Atan2 Block.zip
(101.96 KiB) Downloaded 888 times
Motor+Power+Meter.zip
(167.07 KiB) Downloaded 945 times
And some more :-
pow.zip
(65.9 KiB) Downloaded 1081 times
sin_cos_11_block.zip
(82.55 KiB) Downloaded 972 times
Square_root_block.zip
(58.5 KiB) Downloaded 964 times
