BBCode Wishlist
sebi-mylegopage
Re: BBCode Wishlist
I have downloaded the php script, and have uploaded it on my homepage:
http://my-lego-page.cwsurf.de/latex2png.php
and: http://mylegopage.my.funpic.de/latex2png.php
--> Don't Work. I think a other file is needed too?
Re: BBCode Wishlist
Look at the first couple of lines in the script. They contain the names of the binaries you need on the webserver.
Re: BBCode Wishlist
Xander,
if I take the latex script from http://www.matheboard.de then the script is working well at our forum: http://www.mindstormsforum.com/viewtopic.php?f=14&t=38
(ok:)
if I take your latex script url instead it doesn't work neither.
(faulty:)
maybe you'll also have to replace by something different if you don't take our German hosted latex script.
As sebi told me he changed the BBcode definition that he posted before in only 1 respect: he replaced "{IDENTIFIER}" by "{TEXT}".
(ok:)
<img src="http://www.matheboard.de/latex2png/latex2png.php?{TEXT}" alt="Formel">(faulty:)
<img src="http://mindboards.sourceforge.net/latex2png.php?{TEXT}" alt="Formel">Code: Select all
alt="Formel"As sebi told me he changed the BBcode definition that he posted before in only 1 respect: he replaced "{IDENTIFIER}" by "{TEXT}".
Re: BBCode Wishlist
If you are using www.matheboard.de url, then you are asking their server to generate the latex image, this cost computing power and bandwidth to the matheboard server. If you host the script on your server (or mindboards server), that's OK.doc-helmut wrote:naaah - what do you mean by
"stealing bandwidth and server resources" ?!?
Re: BBCode Wishlist
ok, let's do it!
(1st, Xander may try to run the matheboard script for testing and then
2nd, may use a hosted script on sourceforge or sebis homepage server or where ever)
Re: BBCode Wishlist
test:
} \cdot \exp \left( \frac{arg(c) + k \cdot 2 \pi}{n} \ i \right) \ |\ k \in \left\{ 0, 1,..., n-1 \right\} \right\})
[math]X = \left\{ \sqrt[n]{abs(c)} \cdot \exp \left( \frac{arg(c) + k \cdot 2 \pi}{n} \ i \right) \ |\ k \in \left\{ 0, 1,..., n-1 \right\} \right\}[/math]Re: BBCode Wishlist
Helmut,
It is not working at the moment and I have no idea why. I don't really have the time at the moment to figure out why; it's a week until my robot is going to be on display at Lego World and a lot of work still needs to be done.
Re: BBCode Wishlist
it was only a test, not a hint
who ever likes it when it works: have a look at our mindstormsforum http://www.mindstormsforum.com/viewtopi ... 4&p=53#p53
Re: BBCode Wishlist
Can we get and to work?
<s>Maybe this?</s>
Or even:
If you can read this, [s]I will kill you[/s] good job.Or even:
[s=2]Double slashed text. When one slash isn't enough![/s]Commit to LEGO Mindstorms Robotics Stack Exchange:
Re: BBCode Wishlist
I assume that by slashed text, you don't mean something like /hello/ but rather strike-through.
