Wanted: Firmware Hackers...
Re: Wanted: Firmware Hackers...
It might be painfully obvious, but I'll ask anyways. Ever heard of Google?
nxtboyiii
Post by nxtboyiii »
I've tried searching Google and couldn't find the right results. :(
I'm sure you could find something with the right keywords. Programming tools like these usually have documentation stored somewhere. Like Xander said, read, read, read! That's the only way to become truly proficient at programming.
mrblp
Post by mrblp »
nxtboyiii wrote:But how do I actually compile it into an rfw?
nxtreme wrote:I'm sure you could find something with the right keywords. Programming tools like these usually have documentation stored somewhere. Like Xander said, read, read, read! That's the only way to become truly proficient at programming.
You are both right: There is no .rfw-output when compiling. It is not easy to find out this when never worked with embedded systems and you only get this information by asking or by trial and error.
On the other hand - when the developement environment is once started and working - nxtboyiii - it's you to start coding and understanding the fw-code.
When compiling the source code with the "Binary Output"-Settings, there will be a LMS_V02.a79-file in the Object folder. This file is the resulting firmware. At the Project Options->Linker->Extra Output-Tab you can change the output filename to rfw, at the Project Options->Linker->Processing-Tab you can set it to fill the empty memory with 0xff.
Have fun!
Bye - marvin
Bye Marvin
nxtboyiii
Post by nxtboyiii »
Can I compile the firmware using the LMS_ARM instead of the LMS_V02 because the enhanced firmware only includes the LMS_ARM, not the LMS_V02.
mrblp
Post by mrblp »
schodet wrote:The first commit split cCmdWrapDrawPicture in two parts, the second one is a really dirty hack to display .ric files in the "Sound files" menu ;-).
Now I have integrated your patch into my ui frame. Yes it works - thanks a lot :-) And I found out I have to call cCmdRestoreDefaultScreen before exiting.
Here is my new version ;-)
Bye - marvin
lms_arm_no_datalog_obp_v1.29c.zip
No Datalog / View / TryMe / OnBrickProgramming;
Graphic file view / send / delete added (.ric)
(73.31 KiB) Downloaded 725 times
Bye Marvin
schodet
Post by schodet »
nxtboyiii wrote:Can I compile the firmware using the LMS_ARM instead of the LMS_V02 because the enhanced firmware only includes the LMS_ARM, not the LMS_V02.
I suppose yes, let's try it (Well, of course I did not say this, do this at your own risks!)
Could you please start another topic if you still have questions about how to compile?
schodet
Post by schodet »
Nice :)
It works on my brick too.
mrblp
Post by mrblp »
Hello all,
I have the ric support integrated in the standard 1.29 as well. You can download it as binary here.
Once I have all versions stable I will send the source code patches to John - I think he will add parts of it to the extended fw, too.
Bye - marvin
lms_arm_ric_added_v1.29c.zip
Standard v1.29 with ric file support added.
(80.99 KiB) Downloaded 775 times
Bye Marvin
