NXT PROBLEM
Re: NXT PROBLEM
I gave you the code, but you didn't even refer to it, whether it is good or not. Not a pinch of a code-feedback from you:) Only words...
Please modify it if it's wrong...
task main() {
int y;
int i;
int tab[100];
SetSensorLowspeed(IN_4);
for(int i=0; i<100; i++)
tab[i]=SensorUS(IN_4);}
for (i=0;i<100;++i) {
y=tab[i];
if (i==99) ClearScreen();
LineOut(i, y/4, DRAW_OPT_NORMAL);
NumOut(0,56, y, DRAW_OPT_CLEAR);
while (true);
Re: NXT PROBLEM
aaah, now - you edited your post.
The code won't work. The reasons are quite the same as before.
The indentations are wrong, additionally.
Think about what your doing.
Describe what you're doing, line for line.
test the code.
If you have no NXT to test, wait until you'll have one again.
task main() {
int y;
int i;
int tab[100];
y=tab[i];
while (true);
}The indentations are wrong, additionally.
test the code.
Re: NXT PROBLEM
You see, only words, not code:) Ok, maybe I will find somebody else who will help me more, because you just don't want to...
Re: NXT PROBLEM
I clearly get it. You said that you won't write the whole code for me. Ok, I wrote sth, and you would only apply some changes or give some advice what to change in this code but you are not willing to..so? As you can see I don't know how to change it, what to do, I've joined this forum, so that somebody would give me a helping hand, modify code.
Re: NXT PROBLEM
no, you don't get it.
It seems you can't read!
https://sourceforge.net/apps/phpbb/mind ... =30#p16535
http://sourceforge.net/apps/phpbb/mindb ... 814#p16545
Re: NXT PROBLEM
Hmm, please be so kind and discontinue sharing such tainted opinions. I can read but it is clear for me that you can't. If you really don't want to help me, just say it. Because now, you only write about indentations and not about the core thing which is the code, I wonder why...
