New BricxCC and NBC/NXC release
Re: New BricxCC and NBC/NXC release
I seem to be able to open it perfectly with the release from last summer (3.3.8.7). However, this program won't open without crashing that release.
#define SHORT_WAIT 3                //short wait for value to stabilize
int A,B,C,E,AF,BF,CF,EF,Final;                             //global
  SetUserDisplay (Final,0);
  SetSensor (SENSOR_1, SENSOR_TOUCH);
  Wait (100);
  SetSensor(SENSOR_1, SENSOR_LIGHT);    //power on sensor by making it light type
  SetSensorType (SENSOR_2, SENSOR_TYPE_TOUCH);
  while (true)                      //loop forever
    if (SENSOR_1== 100)
        SetSensor(SENSOR_1, SENSOR_TOUCH);
        Wait(SHORT_WAIT);
    A = SENSOR_1*1;                   //read the A and scale by 1
    SetSensor(SENSOR_1, SENSOR_TOUCH);  //toggle power to change to channel 2
    Wait(SHORT_WAIT);
    B = SENSOR_1*1;                   //read the B and scale by 1
    SetSensor(SENSOR_1, SENSOR_TOUCH);  //toggle power to change to channel 3
    Wait(SHORT_WAIT);
    C = SENSOR_1*1;                   //read the C and scale by 1
    SetSensor(SENSOR_1, SENSOR_TOUCH);  //toggle power to change to channel 0
    if (A == 0) { AF = 0; }
    else{ AF = 1; }
    if (B == 0) { BF = 0; }
    else { BF = 10; }
    if (C == 0) { CF = 0; }
    else{ CF = 100; }
    EF = 1000;
    Final = AF + BF + CF + EF;
I have the programs saved as .nqc files. When I go to open a program, the default type is NXC, so I have to click on the dropdown menu and select NQC. Yes I did recently change to tabbed mode. Should I switch back to MDI and see what happens?
afanofosc wrote:You did recently switch from MDI mode to tabbed mode, didn't you?
10 Days, 23 Hours, and 52 minutes ago.
Muntoo "still trying to win next year's prolific poster award" ;)
muntoo wrote:...Muntoo "still trying to win next year's prolific poster award" ;)
LOL
Keep trying, and the banhammer will swing for the first time (I think first anyhow) :lol:
Okay,I switched to MDI mode, and so far so good (tried with both versions of BCC). I opened 20 programs (that's all I have on this computer so far), and it didn't crash once :D Hopefully my success won't be short-lived.
slavkozn
Post by slavkozn »
afanofosc wrote:I will correct the source archive.
OK, thanks
Edit: i was success, the packages uploaded in my repo (http://slavino.sk/ulozisko-apt) for both (i386, amd64) archs.
schodet
Post by schodet »
Thanks for including absolute regulation!
Here is some precision about questions I have seen:
About SetMotorRegulationTime: this can be used to change the interval between regulation update. You really should reduce it to 10 ms to use absolute regulation. More details.
About SetMotorRegulationOptions: this provides advanced control on the control loop. The default firmware code will limit P term and I term of the PID algorithm to 50 % of the output power. If you want a pure P control loop for example, this is not optimal. Using the OUT_REGOPTION_NO_SATURATION options, the limit is removed and you can reach full motor power with only the P part.
About MaxSpeed: this is between 0 and 100. 0 is a special value which means "no limit, no speed control".
About MaxAcceleration: this is also between 0 and 100. 0 is a special value which means "no acceleration control, always use max speed". For any other value, MaxSpeed should be set. You will usually use small Acceleration values or else the effect will be unnoticed.
There is a tutorial here.
