The Freelug code is quite long because it parses two different types of NMEA string.
If you select which type of string you want to use, you can just delete all references to the other.
Adding a Bluetooth GPS
Re: Adding a Bluetooth GPS
pepijndevos
As well as all code splitting up small arrays.
-- Pepijn
