FW: bad rand generator: distribution/prevalences/periodicity
Re: FW: extremely poor equal distribution of random prevalences
new test:
how is the distribution of two consecutive numbers?
(all consecutive numbers should be nearly equally distributed, otherwise there must be clusters or local minima or maxima or hyperplane behaviors).
This is the test code:
// Test on statistical equal distributionof (n, n+1)
// of Lego and customized randomization functions
// ver. 1.1
  TextOut(_x, _y, sval1); \
char LCDline[]={56,48,40,32,24,16,8,0};
// randomize functions
// Kernighan & Ritchie LCG (linear congruence generator)
// global variables and functions to plant a random seed and to randomize
// how to use:
// sKrand(x)                         // x = val. for repet. sequences
// myVar = Krand() % 100;           // assignes a random number
unsigned long _RAND_SEED_ = 1;      // 1= default value (program start)
unsigned long _OLD_SEED_  = 1;
unsigned long Krand()               // custom random function
  _RAND_SEED_ = _RAND_SEED_ * 1103515245 + 12345;
  return (_RAND_SEED_ % (RAND_MAX + 1));
void sKrand(unsigned long seed)      // seeds for a new random series
  if (seed==0)                      // 0: a "real" randomized random seed
    seed = ( CurrentTick()*BatteryLevel() );
  }  // substitute to time(0)
  if (seed==-1) {                   // -1: restore last random series
    seed = _OLD_SEED_;
  _OLD_SEED_  = seed;
  _RAND_SEED_ = seed;               // patch for rand_ function
// Mersenne Twister by Makoto Matsumoto & Takuji Nishimura
const int N_MTW = 25;
const int M_MTW = 7;
const unsigned long A_MTW[] = {0, 0x8ebfd028};
unsigned long y_MTW[25];
int i_MTW;
char virgin_MTW=TRUE, new_MTW=FALSE;
void InitMTW() {
  i_MTW = N_MTW+1;
unsigned long sMrand(unsigned long x) {
  unsigned long r, s;
  int k;
  if (x==1) InitMTW();
  else {
    InitMTW();
    if (x==0) {x=Random(CurrentTick());}
    for (k=0 ; k<25 ; ++k) {
      InitMTW();
      r = 9+x;
      s = 3402+x;
           r = 509845221 * r + 3;
           s *= s + 1;
           y_MTW[k] = s + (r >> 10);
      new_MTW=TRUE;
unsigned long Mrand(void) {
  unsigned long r, s, e;
  int k;
  if (virgin_MTW) {InitMTW(); virgin_MTW=FALSE; }
  if (i_MTW >= N_MTW) {
      if ((i_MTW > N_MTW) && !new_MTW) {
         r = 9;
         s = 3402;
         for (k=0 ; k<N_MTW ; ++k) {
           s *= s + 1;
      for (k=0 ; k<N_MTW-M_MTW ; ++k)
         y_MTW[k] = y_MTW[k+M_MTW] ^ (y_MTW[k] >> 1) ^ A_MTW[y_MTW[k] & 1];
      for (; k<N_MTW ; ++k)
         y_MTW[k] = y_MTW[k+(M_MTW-N_MTW)] ^ (y_MTW[k] >> 1) ^ A_MTW[y_MTW[k] & 1];
      i_MTW = 0;
  new_MTW=false;
  e = y_MTW[i_MTW++];
  e ^= (e << 7)  & 0x2b5b2500;
  e ^= (e << 15) & 0xdb8b0000;
  e ^= (e >> 16);
  return e;
  long i, j, old;
  long H[16];            // prevalence counter array
  float x;
  sKrand(2);  sMrand(2);
                         // print output matrix
  for (j=0; j<16; ++j) {
    printf1(0+(j%2)*50, LCDline[j/2], "%2d:", j);
  for (i=-1; i<= (1024 << 7); ++i) {
    // 128 k  randomizations of numbers between 0...15
    j=rand()%16;        // std Lego FW rand
    //j=Random(16);       // NXC John Hansen rand
    //j=Krand()%16;       // Kernighan and Ritchie LCG rand
    //j=Mrand()%16;       // Mesenne Twister rand
    if ((j==old+1) || ((j==0 && old==15)))
    if (i>=0) H[j]+=1;   // add +1 to the prevalence to the related counter
    old=j;
                         // print prevalence test distribution
    printf1(16+(j%2)*50,LCDline[j/2], "%5d", H[j]);
  PlaySound(SOUND_FAST_UP);
  while(!ButtonPressed(BTNCENTER, true));
                               printf1(0,56, "count=%8d", i+1); //  !!
  j=ArrayMin (H, NA, NA);      printf1(0,48, "min  =%8d", j);
  j=ArrayMax (H, NA, NA);      printf1(0,40, "max  =%8d", j);
  j=ArrayMean(H, NA, NA);      printf1(0,32, "mean =%8d", j);
  x=ArrayStd (H, NA, NA);      printf1(0,24, "stand=%8.2f", x);
  while(1) {}
This is for lego rand()%16:
worst case:<br />Lego fw rand() % 16
worst case:
Lego fw rand() % 16
worst case:<br />Lego fw rand() % 16 statistics
worst case:
this is with John's NXC Random (16) - much better!
better: <br />John's NXC Random(16)
better:
better: <br />John's NXC Random(16) statistics
better:
this is the result with Kernighan + Richie's LCG Krand()%16:
random seed sKrand(1);
also much better (mean better but admittedly stand_dev a little worse than John's code)^^ - but that may depend on modulus ;)
also much better:<br />Kernighan + Richie's LCG Krand()%16
also much better:
also much better:<br />Kernighan + Richie's LCG Krand()%16 statistics
also much better:
best:
Mersenne Twister!
Mrand%16, random seed sMrand(1);
best:<br />Mersenne Twister Mrand()%16
best:
best:<br />Mersenne Twister Mrand()%16 statistics
best:
next test:
test on periodicity length ("Infinite Monkey Test"):
the first 9 randomized numbers are stored and then a repetitive randomization is started until the start sequence is reached again.
By a random(100) the probability of an accidentally re-drawn start pattern is 1 : 100^9 (nearly inifinte improbability ^^).
So the longer the minimum periodicity length is until a start sequence is re-generated again - : the better is the random number generator.
This is the test source code (test algorithm: a finite state machine (FSM), inspired by a basic idea of hergipotter - I'm really really curious if it works and what the results are like...):
// Test on periodicity length ("Infinite Monkey Test"):
// ver. 1.6
    seed = _OLD_SEED_;
  _OLD_SEED_  = seed;
int i_MTW;
void InitMTW() {
  i_MTW = N_MTW+1;
  unsigned long r, s;
  int k;
  else {
    InitMTW();
      InitMTW();
      r = 9+x;
      s = 3402+x;
           s *= s + 1;
      new_MTW=TRUE;
  int k;
         r = 9;
         s = 3402;
           s *= s + 1;
      i_MTW = 0;
  new_MTW=false;
  e = y_MTW[i_MTW++];
  e ^= (e >> 16);
  return e;
unsigned long i;       // counter
unsigned long H[10];   // for start sequence
int maxZ;              // maximum level for subsequences
void showWhat(){
  float V;
  int r, c;
  TextOut( 0,56, "start rand sequence:");
  for (c=0; c<3; ++c) {
     r=H[c]; printf1(c*30,48,"%3u",r);
     r=H[c+3]; printf1(c*30,40,"%3u",r);
     r=H[c+6]; printf1(c*30,32,"%3u",r);
  printf1( 0,24,"maxLevel=%2u", maxZ);   // max. reached level
  if (maxZ>0) {                          // number of max. reached level
    printf1(60,16,"sub%3u", H[maxZ-1]);
  printf1(0, 8,"count=%d", i);
  V=BatteryLevel()/1000.0;
  printf1(0, 0,"Volt=%6.3f",V);
  unsigned long j;
  float x;
  int level;
  sKrand(1);  sMrand(1);
  for (i=0; i<10; ++i) {  // start store 9 generated numbers (1st dropped)
    j=rand()%100;        // std Lego FW rand
    //j=Random(100);       // NXC John Hansen rand
    //j=Krand()%100;       // Kernighan and Ritchie LCG rand
    //j=Mrand()%100;       // Mesenne Twister rand
    if (i>0)
      H[i-1]=j;            // end store the first 9 generated numbers
  showWhat();
  Wait(1000);
  level=0;
  while(1) {
      if (j==H[level])  {
        level+=1;
        if (level>maxZ)   {  maxZ=level;  }
        if (level>0)    {
          level=0;
      }  // if
      if (level>maxZ)   {
        maxZ=level;
      i+=1;
      while (ButtonPressed(BTNCENTER, false)) {
        showWhat();
        printf1( 0,16,"rand=%3u", j);          // current rand number
      if (ButtonPressed(BTNRIGHT,  false))  {
        showWhat();
        Wait(200);
      if ((i%2000==0)|| (i<1000)) {
        showWhat();
      if (level>1) {
        if (level>3) PlayTone(200*level, 100);
        showWhat();
        Wait(200); }
      if (maxZ>8)
        showWhat();
        printf1(0,16, "strtseq.reach%3u",j); // current number of final level
        while(1);
run (1): periodicity=113484 iterations
Lego fw rand()%100 <br />run (1): periodicity=113484 iterations
Lego fw rand()%100
run (2): periodicity=2134868 iterations
Lego fw rand()%100 <br />run (2): periodicity=2134868 iterations
Lego fw rand()%100
run (3): periodicity=4180450
Lego fw rand()%100 <br />run (3): periodicity=4180450
Lego fw rand()%100
again Lego fw rand()%100.
that's really odd:
in run (4): repetitive sequence already after 50808 iterations!!
Lego fw rand()%100 <br />run (4): periodicity=  50808
Lego fw rand()%100
run (5): periodicity = 1542188 iterations
Lego fw rand()%100 <br />run (5): periodicity= 1542188 iterations
Lego fw rand()%100
run (6): periodicity = 996500 iterations
Lego fw rand()%100 <br />run (6): periodicity= 996500  iterations
Lego fw rand()%100
now
NXC Random(100):
run (1): 111176 iterations
NXC Random(100)
NXC Random(100)
run (2): 3022238 iterations
NXC Random(100)
NXC Random(100)
run (3): 112760 iterations
NXC Random(100)
NXC Random(100)
interim report:
3 NXT bricks using Krand() modulo 100 (Krand: the Kernighan & Richie LCG ) have been running simultaneously since Sunday evening 7 pm (GMST+1) , still running.
They had been initialized with different seeds (sKrand(1), sKrand(2), sKrand(3) ).
Meanwhile there have been > 300 million random iterations each, maximum subsequence levels are (as expected) 4 at all 3 NXTs , no complete level-9 start sequences have been found / re-generated so far:
(prematurely user interrupted because of other purposes !!)
Kernighan & Richie LCG Krand() % 100 seeded by sKrand(1)
Kernighan & Richie LCG Krand() % 100 seeded by sKrand(2)
Kernighan & Richie LCG Krand() % 100 seeded by sKrand(3)
to remember: As shown above, the Lego function rand() has regenerated that level-9 start sequence already again after (mostly) > 100,000 up to < 5 millions of iterations ("periodicity length") - by using rand()%100 as well as by using Random(100)!
(statistical probability = 1: 100 9 = 1: 1018 = 1: 1 quintillion ).
Again: does anybody know what algorithm exactly the Lego FW rand() uses? My suspect: it uses sth like RANDU :shock:
ps
I had to prematurely stop 1 of the 3 running NXTs because I need it for other purposes...
Re: FW: bad rand generator: distribution/prevalences/periodicity
This is the intermediate summary of the previous test results (tests yet running/pending)
               equality of      equality of      random series  seed by
               prevalences of   prevalences of   periodicity    constant or
               single numbers   (n, n+1) tuples  length         random seeds
rand() % n       - - - - -        - - - - -       - - - - -       - - -
Random(n)           + +              + +          - - - - -       - - -
K&R LCD
Krand() % n         + +              + +             + +          + + +
Mersenne                                            + + +
Twister            + + +            + + +           10^240         + +
Mrand() % n                                      (not tested)
The results of the Mersenne twister periodicity length (in theory:> 10240) have not been finished.
I want to stress the results of the periodicity length - what actually is the meaning of a very short periodicity length of e.g. 1 million?
It means, that every 1 million iterations all randomized patterns repeat themselves. (And for this point of view it actually does not matter if it's now 5 millions or just 50 thousand.)
That means, that (if randomized out of a set of 100) almost
1018 different possible combinations of 9 or
1016 different possible combinations of 8 or
1014 different possible combinations of 7 or
1012 different possible combinations of 6 or
1010 different possible combinations of 5 consecutive numbers
WILL NEVER BE GENERATED.
As we know, even every LCG processes sorts of hyperplane behaviours.
But for not-critical, fast number generation he is fast and good enough and it could be the second best choice.
But for a high quality needed for stochastical filters such as Monte Carlo filters the slower but very high-quality Mersenne Twister should be preferred. Nevertheless, some results of the Mersenne Twister are still pending.
What sort of real-world LEGO NXT device are you going to run with 1 million iterations of random numbers? A rover? A humanoid? A robotic arm? A maze solver? A balancing bot?
And why do you persist in using a widely known to be bad algorithm for generating random numbers within a small numeric range?
