Finding the biggest number in NXC
penguinplus
I have 5 variables:
L1
L2
L3
L4
L5
And they all start out a 0. At the end of the program they are different numbers. I need to find the biggest variable at the end. How do I do that? Please help.
-Penguinplus
L1
L2
L3
L4
L5
-Penguinplus
I take the place of Penguinplus from the old forums.
Re: Finding the biggest number in NXC
Couldn't find any inbuilt functions for min or max, which surprise me.
As a non-programmer, I would write something like
max = 0;
if (L1>max) max = L1;
if (L2>max) max = L2;
and so on.
Only works if the numbers are all positive.
max = 0;
and so on.
penguinplus
So nobody knows how to find the max number out of the variables?
h-t-g's method should be used if you want to get the biggest value hold by those variables.
If you want the name of that variable, use a variant:biggest_var_id will indentify which variable it is. It is good practice to use a special ID for invalid IDs so that you can do error checking.
Notice the "INT_MIN" constant. This will be replaced by the smallest value that variable type can hold so that this also will work with negative numbers. There is also "INT_MAX" which holds the largest value, and variants for every other integer type. Check the documentation.
Another thing to remember is that several variables might contain the same value and that you therefore might have several variables which contains the biggest value. You can do some more advanced stuff if you want to check for that.
Also note that I used ">=" instead. In case all variables contain INT_MIN, biggest_var_id would have stayed as '0' if you had used ">".
int biggest_var_id = 0;
int biggest_value = INT_MIN; //Smallest value an int type can hold
if( L1 >= biggest_value ){
biggest_var_id = 1; //i.e. L1
biggest_value = L1;
if( L2 >= biggest_value ){
biggest_var_id = 2; //i.e. L2
biggest_value = L2;
//Repeat for each variableNotice the "INT_MIN" constant. This will be replaced by the smallest value that variable type can hold so that this also will work with negative numbers. There is also "INT_MAX" which holds the largest value, and variants for every other integer type. Check the documentation.
penguinplus
So how would I use that in my code?
Here's my version:
EDIT: Realized you can do the same thing with
EDIT: For "ids":
With your code:
arr_max = ArrayMax(arr, NA, NA); EDIT: For "ids":
#define max(a,b) ((a)>(b)?(a):(b))
#define ID unsigned int
ID lmax(long &arr[])
unsigned int arr_len = ArrayLen(arr);
ID ret = 0;
if(!arr_len)
return(ret);
for(unsigned int i = 1; i < arr_len; ++i)
ret = arr[ret] > arr[i] ? ret : i;
return(ret);
}Code: Select all
long L[5] = {42, -1, 96, 0xFFFFFFFF, 0x7FFFFFFF};
NumOut(0, 0, lmax(L), 0);
Wait(1000);
penguinplus
I still don't get it. Could you add it straight with this code and just find which variable is the biggest in the end? Here is the code.
while(true)
ClearScreen(); //Clear the screen
SetSensorLight(IN_3); //Set the light sensor
TextOut(0,LCD_LINE1,"The screen works"); //Test the screen
L1 = 0; //Light sensor reading #1
L2 = 0; //Light sensor reading #2
L3 = 0; //Light sensor reading #3
L4 = 0; //Light sensor reading #4
L5 = 0; //Light sensor reading #5
L1 = Sensor(IN_3); // Set the variable
TextOut(0,LCD_LINE2, "L1="); // Screen debugging
NumOut(20,LCD_LINE2, L1 ); // Screen debugging
Wait(500); // Wiat to read the screen
RotateMotor(OUT_C, 75,360);
RotateMotor(OUT_A, 75,-355);
L2 = Sensor(IN_3); // Set the variable
TextOut(0,LCD_LINE3, "L2="); // Screen debugging
NumOut(20,LCD_LINE3, L2 ); // Screen debugging
L3 = Sensor(IN_3); // Set the variable
TextOut(0,LCD_LINE4, "L3="); // Screen debugging
NumOut(20,LCD_LINE4, L3 ); // Screen debugging
L4 = Sensor(IN_3); // Set the variable
TextOut(0,LCD_LINE5, "L4="); // Screen debugging
NumOut(20,LCD_LINE5, L4 ); // Screen debugging
L5 = Sensor(IN_3); // Set the variable
TextOut(0,LCD_LINE6, "L5="); // Screen debugging
NumOut(20,LCD_LINE6, L5 ); // Screen debugging
Wait(5000); // Wiat to read the screen
}I take the place of Penguinplus from the old forums.
Here's the code:
I've left a few comments. If you need any more help, just ask.
I suspect you're not familiar with arrays - read up on them here. I recommend reading this C++ Tutorial (most of it; you can skip the last few Advanced ones).
SetSensorLight(S3);
int L[5];
int L_max;
int y;
while(true)
// Set things up.
y = LCD_LINE2;
// Determine and display L0, L1, L2, L3, L4.
for(unsigned int i = 0; i < 5; ++i)
// Get sensor value.
L[i] = Sensor(S3);
// Convert L and i to string.
string szL = NumToStr(L[i]);
string szi = NumToStr(i);
// Display.
TextOut(0, y, "L[" + szi + "] = " + szL);
Wait(500);
// Rotate Motors.
RotateMotor(OUT_C, 75, 360);
RotateMotor(OUT_A, 75, -355);
// Move display down one line.
y -= 8;
// NEW CODE!
// Determine largest L element value.
L_max = ArrayMax(L, NA, NA);
NumOut(0, y, L_max, 0);
Wait(4500);
}I suspect you're not familiar with arrays - read up on them here. I recommend reading this C++ Tutorial (most of it; you can skip the last few Advanced ones).
penguinplus
I get this error
Download the latest test release. (It's this one, at the moment.) More info here.
Don't forget to download the latest firmware onto your NXT brick as well.
