[NXC] What is wrong with this sound sensor graphing program?
airplaneguru
Post by airplaneguru »
Hey,
How come this simple sound sensor graphing program I made in NXC is not working? Nothing is showing up on the screen. It should log the sound level each second and display the sound level on a bar graph that moves backwards. Do you have any suggestions?
Thank you for your help!
-Aaron
#define MIC SENSOR_1
  SetSensorSound(IN_1);
  int x[];
  ArrayInit(x, 0, 100);
  while(true){
    x[100] = MIC;
    for(int i=99; i>=0; i-=1 ){
    x[i] = x[i++];
    int i=99;
    for(int p=0; p<=100; p++ ){
    LineOut(p,0,p,x[p]);
    int p=0;
    Wait(1000);
Re: [NXC] What is wrong with this sound sensor graphing program?
First of all, x[100] doesn't exist. You need to do ArrayInit(x, 0, 101); if you want that. (Not sure why you would, though.)
Your program is stuck on:
		for (int i = 99; i >= 0; --i) {
			x[i] = x[i++];
i will never equal anything less than 99.
Try:
task main() {
	int y[];
	ArrayInit(y, 0, 100);
	while (true) {
		for (int i = 0; i < 99; ++i) {
			y[i] = y[i + 1];
		y[99] = MIC;
		for (int x = 0; x < 100; ++x) {
			LineOut(x, 0, x, y[x]);
		Wait(1000);
Before trying muntoo's suggestion, please tell us what you want the for loop to accomplish. It is not at all clear from your uncommented code. It would be utter nonsense to iterate through every element in your 100 element array and move the value from the next element into the current element so I am sure that is not what you are trying to do.
.@John He's trying to make a FIFO stack, push off an old value, add the new sensor value, and display those results on the screen.
I suppose a faster way to do it would be:
#define READ(arr,len,start,offset) arr[(start+offset)%len]
#define NEXT(len,start) start = (start + 1) % len;
task main() {
   int y[];
   unsigned int y_start = 0;
   unsigned int y_len = 200;
   ArrayInit(y, 0, 200);
   while (true) {
      READ(y, y_len, y_start, 100) = MIC;
      NEXT(y_len, y_start)
         LineOut(x, 0, x, READ(y, y_len, y_start, x));
      Wait(1000);
muntoo, I do not think it is possible for you to know what someone else was trying to do with the kind of certainty you possess. Why not let him answer my question? If you want to simulate a stack with 100 maximum entries then use two arrays, ArrayBuild, ArraySubset, and ArrayInit.
  SetSensorSound(S1); // don't use IN_1 in NXC code - it is for NBC use
  int x[100], tmp[];
  while (true) {
    int value = MIC;
//    ArraySubset(tmp, x, 0, 99); // all elements except the last
//    ArrayBuild(x, value, tmp); // put the new value at the front
    ArraySubset(tmp, x, 1, NA); // all elements except the first
    ArrayBuild(x, tmp, value); // put the new value at the end
    ArrayInit(tmp, 0, 0); // free memory
    for(int p=0; p<100; p++ ) { // I disagree with those who recommend using pre-increment - especially in NXC code
    Wait(SEC_1);
