NXT run program on launch
shadowwatch
hello,
I have a question as the title says I wan't to let my NXT run a program on startup so when I turn the NXT on it runs a program right away.
Is this possible and how?
Re: NXT run program on launch
Name the program "! Startup" (minus the quotes).
shadowwatch
that doesn't work I made my programm in Lego Mindstorms programming (the program that comes with the nxt)
sidneys1
Or more accurately:mattallen37 wrote:Name the program "! Startup" (minus the quotes).
!StartupHave a nice day,
~Sidneys1
No, I'm totally sure it has a space (just tested it). It was an NXC program, with the latest enhanced FW (shouldn't matter).
Edit: I just tried without the space, and it didn't work.
shadowwatch
It looks like you got it right, but you need to use a capital "S" (not "s").
savedcoder
What firmware does your NXT have? I think this only works with the NBC/NXC enhanced firmware.
To God be the glory, great things He has done;
So loved He the world that He gave us His Son,
Who yielded His life an atonement for sin,
And opened the life gate that all may go in.
I don't think so, at least I can't see why it would matter. No matter what lego FW you are using, it should play ! Startup as soon as you turn it on (normally a sound file).
savedcoder
Oohhhh, I just realized something: Everyone said "! Startup", but like you just pointed out, that's a sound file. (Actually "! Startup.rso".) And yeah, that is supported in the stock firmware.mattallen37 wrote:I don't think so, at least I can't see why it would matter. No matter what lego FW you are using, it should play ! Startup as soon as you turn it on (normally a sound file).
However, shaddowwatch is trying to run a program on startup. That, I'm pretty sure, is supported only in the EFW, and the program must be named "! Autorun" (.rxe).
I should have realized that sooner...
