Fresh install of BCC won't compile SendRS485String
I just installed the latest official release of BCC on an "older" Win XP machine, and then installed the latest test release over it. I have the drivers working fine (I can connect and communicate with the NXT through USB). I went through and set all the preferences to how they are on my main computer. I can properly compile several programs; however, it's complaining about me using SendRS485String. Here is the error list:
# Error: Undefined Identifier SendRS485String
File "C:\Documents and Settings\Compaq_Owner\My Documents\Dropbox\computer sharing\Lego\Bricx CC\MyLib\My DI WIFI RS485.nxc" ; line 4
#    SendRS485String(
# Error: ';' expected
#    SendRS485String(S
The exact program compiles fine on the other computer though.
Oh, and it does highlight the syntax properly, and the function is in the templates list.
Re: Fresh install of BCC won't compile SendRS485String
My best bet is that it is not set to compile for the enhanced firmware.
The checkbox for Enhanced firmware is definitely checked, as are the boxes for internal compiler, NXT 2.0 compatible firmware, and automatic firmware version.
Well, ain't that interesting... I changed no settings, and now it compiles (and works) fine. Problem solved I guess.
