When I fire up BricxCC in Windows 7 environment I tell the program to look for IR Tower, the green light glows for a fraction of a second then the laptop freezes and the only way I can get it back is to unplug it from the mains and remove the battery, then reboot.
I guess I need to set up the tower in a different way - at present it is as set up by RIS. Help!!
Peter
Can't connect usb IR Tower to RCX2 in Windows 7
Re: Can't connect usb IR Tower to RCX2 in Windows 7
There are no Win 7 64bit drivers for the Lego USB IR Tower.
foamcleaver
Its 32 bit Win 7 I'm running.
Pete
Pete
Well, then you may be in luck. Try using the drivers here (direct download link).
foamcleaver
That's absolutely excellent. It's worked just fine for me. Thank you very much.
Pete
Pete
An even better source than Matt's RobotC link is the unofficial official LEGO MINDSTORMS 2.5 SDK page on Philo's site:
http://www.philohome.com/sdk25/sdk25.htm
The bricxcc home page links to Philo's page for the 2.5 SDK download. I should add some text to mention that it is not optional that you install the usb tower drivers if you are trying to use BricxCC with the USB tower and that if you have a multi-core or hyperthreaded CPU you need to get the updated tower drivers.
foamcleaver
Thanks for your link John, its much appreciated. Thanks for your help. Pete
