NXC: string-upcase? string-downcase?
hi,
do we already have functions for string upcase/downcase in NXC?
I know that there's toupper but it's designed for a single char, not for strings (CMIIW)
nxtboyiii
Re: NXC: string-upcase? string-downcase?
Post by nxtboyiii »
just do this:
 string s="lorem ipsum";
 char s_data[];
 byte length=StrLen(s);
 ArrayInit(s_data,0,length);
 StrToByteArray(s,s_data);
 for(int c=0; c < ArrayLen(s_data); c++)
  toupper(s_data[c]);
 ByteArrayToStr(s_data);
I don't think that will work.
Try this:
  TextOut(0, LCD_LINE1, s);
  for(int c=0; c < strlen(s); c++)
    s[c] = toupper(s[c]);
  TextOut(0, LCD_LINE2, s);
  Wait(SEC_5);
yes, this
for(int c=0; c < strlen(s); ++c) s = toupper(s[c]);
is just what I am already doing!
thank you!
If tolower and toupper were native firmware operations you could have used them on arrays too, but it is not the case. Well, there isn't a function to do this in C either AFAIK...
Any particular reason you are looking for such functions? Do you need to do this operation as fast as possible, or just curious if there was a better way to do it?
This version is a bit more efficient:
for( int i=strlen(s); i>=0; i-- )
   s[i] = toupper(s[i]);
Instead of checking the array length each time, it will only be done once in this hence the performance boost. (33%, 22 msec compared to 33 msec with "Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor ".)
If you really want performance try this:
     int i = strlen( s );
     unsigned char c;
     loop_start:
     asm{
       brtst LTEQ, loop_end, i
       sub i, i, 1
       index c, s, i
       brcmp LT, loop_start, c, 97
       brcmp GT, loop_start, c, 122
       sub c, c, 32
       replace s, s, i, c
       jmp loop_start
       loop_end:
This is ~66% (9 msec) compared to the original and even faster if the string contains a lot of non-lower case character as it only overwrites the character if it indeed is lower case.
no, thanks, I'm programming in NXC, never in NBC
(speed is no issue, and if it was, I would wish the fw would work faster)
See this post:
https://sourceforge.net/apps/phpbb/mind ... 150#p12086
uplow.nxc
(393 Bytes) Downloaded 665 times
sry, what is this link for?
Doc,
Did you read the post John linked? :)
yes of course but I didn't understand what this is for (asm, chunkID,...?)
does it mean there now are new functions in the API called UpperCase and LowerCase for strings?
