Hello!
When I try to compile any program, I get an error message: compile failure.
The error codes are:
line 19272, file "NXCDefs.h": Error: number expected
line 19273, file "NXCDefs.h": Error: number expected
I use Bricxcc Version 3.3.8.9 under a german installation. The compiler setting is NXC, the NXCDefs.h is version 92, NXTDefs.h is version 75.
When I check NXCDefs.h under preferences/API, there is no line 19272, it ends with line 15859.
Any ideas?
Thanks a lot.
compile failure in NXCDefs.h
Re: compile failure in NXCDefs.h
hi,
you should first of all upgrade to the latest Bricxcc version (3.3.8.9. + test-release => 3.3.8.10)
nxcdefs.h is currently not needed to be included any more.
Could you post a screenshot of your Compiler|NBC/NXC tab in the Preferences dialog and a simple program (as small as possible) that demonstrates the error you are getting? I assume that even a trivial program (i.e., task main() {}) will result in this error?
As Doc recommended I would also try the very latest test release to see if this problem has been fixed in a more recent build. See http://bricxcc.sourceforge.net/test_releases/
