Turning Bluetooth on, on the NXT through an NXC program
ricardocrl
Post by ricardocrl »
Hey everyone,
I am wondering if it is possible, using NXC, to turn on the bluetooth programmatically, instead of manually through the FW menu. Any ideas?
I see I can check the state, using BluetoothState(), but not setting the state.
Why? Well, sometimes for "no reason", when I start the NXT, the Bluetooth is off. I actually wonder why does it turn off by itself. It is very rare, but it happens.
Thank you!
pepijndevos
Re: Turning Bluetooth on, on the NXT through an NXC program
Post by pepijndevos »
I looked through the docs, as I'm sure I did this in pbLua, but I can't find it fro NBC. I hope someone else does.
-- Pepijn
tabbycatrobots
Post by tabbycatrobots »
Will the command SysCommBTOnOff do what you need?
ricardocrl
Awesome!! That's it! Bad search I did.
Thank you very much! :-)
Cheers!
