Split action in for loop problems
neptunus10000
Post by neptunus10000 »
I have a question. If you see the image below, I want to split (do some things at almost the same time) the control of for example two motors in a for loop. But I can't draw it. If you see the big for loop there it is possible. But this is possible because the switch block is big. How can I draw my problem correct. Can you give me some tips?
Re: Split action in for loop problems
Post by hassenplug »
Here are some tips for NXT-G programming:
http://www.teamhassenplug.org/NXT/NXTGTips/
Check out tip #6
legostormrobot
Post by legostormrobot »
You know, you can just set the switch to go one way if the touch sensor is pressed and the other way if it isn't without having to put a touch sensor block before it... It just condenses your program a bit. Just a thought! ;)
Noah Allen
"I repeat: I come in peace, I mean you no harm, you all will die. Gallaxar out."
Noah Allen
"The computer was invented to solve problems that didn't exist before."
