[LIB] ChooseNum
bungeshea
[LIB] ChooseNum
Post by bungeshea »
I have created yet another library, this one will allow the user to select a number on the NXT screen using the NXT buttons. Uses the CenterText library to center the displayed text.
Use:
#include "ChooseNum.Lib.nxc"
int myvalue = ChooseNum( "Value: ", LCD_LINE3, 0, 9 );
Code:
	ChooseNum.Lib.nxc
#include "CenterText.Lib.nxc"
int ChooseNum(string label, int y, int min, int max) {
	int value = (max+min)/2;
	while(!ButtonPressed(BTNCENTER,0)) {
		string msg = StrCat(label,NumToStr(value));
		TextOut(CenterText(msg), y, msg);
		if(ButtonPressed(BTNRIGHT,0)) {
			while(ButtonPressed(BTNRIGHT,0));
			value++;
		if(ButtonPressed(BTNLEFT,0)) {
			while(ButtonPressed(BTNLEFT,0));
			value--;
		if (value < min) value = max;
		if (value > max) value = min;
	while(ButtonPressed(BTNCENTER,0));
	return value;
Download:
ChooseNum.lib.nxc
ChooseNum.Lib.nxc
(575 Bytes) Downloaded 767 times
cpapple123
Re: [LIB] ChooseNum
Post by cpapple123 »
Thank you for the code and for cluing me in on this functionality of NXC. I'm New to NXC and Mindstorms and learning fast. I modified you code to fit my needs and though I would share with you. I allow the user to hold the key down for scrolling through long list of numbers and also let me preset the start point. Next I might add a function to speed up the scroll if I hold the button for 10 counts.
	ChooseNum.Lib.nxc
     int myvalue = ChooseNum( "TEXT", "LINE#", min, max, preset);
int ChooseNum(string label, int y, int min, int max, int pre) {
     int value; = pre;
			Wait(500);
               //while(ButtonPressed(BTNRIGHT,0));
			value++;
			Wait(500);
               //while(ButtonPressed(BTNLEFT,0));
			value--;
	return value;
