SOLVED: BricxCC Compilation Error, line 1 file "Files"...
jld001
Post by jld001 »
This is the Error:
line 1, file "Files": Error: Unable to find the specified input file
Windows 7, BricxCC 3.3, NXC.
My first line is a comment. Any ideas? Thanks in advance!
My Githubz of Source Codez, in order of awesomeness:
https://github.com/ArtskydJ/NXC_Source
https://github.com/ArtskydJ/NXC_Tests
My Lego Creations, in no particular order:
LEGO Bop-It - http://www.youtube.com/watch?v=6TsqrBVKbj0
LEGO Safe - http://www.youtube.com/watch?v=MyDRfVquHuY
Re: BricxCC Compilation Error, line 1 file "Files"...
what a pity! I just lent my soothsayer's crystal ball to somebody else :(
so all I can assume is that the compiler is probably unable to find the specified input file "Files" in line 1 of your source code
Perhaps you could post the actual line of code?
jld001
Post by jld001 »
Thanks for the concern. ;)
The problem is that I had a path in the EXE Path in the settings. Maybe something to do with the path having the word "Files" in it. I deleted the line, and it works fine now.
(Edit>Preferences>Compiler>NBC/NXC>EXE path)
Re: SOLVED: BricxCC Compilation Error, line 1 file "Files"...
well, my crystal ball prognosticates that your first code line actually could have been no comment. ;)
You can grab a new test release from http://bricxcc.sourceforge.net/test_releases/
This latest test release includes changes to fix this bug. You should now be able to have an EXE Path containing spaces configured in the Preferences dialog for the NBC/NXC compiler without causing compiler errors. Of course, if you use the external compiler then this path must be a valid path to the nbc.exe executable.
