More sensors on 1 in (2 mic, 2 photoresistor) and soon more
floppi
Post by floppi »
I use one PCF8591 for this :
With one input on the nxt, I wanted to have more than one sensor.
I build a circuit with
- 2 microphones with the LM357 IC ( robot is able to detect where does the sound come from ).
- 2 photoresistors ( robot will be able to detect where is the lighter source )
Then I will add a PCF8574 to
- drive 6 output ( motors with external power supply or simply led ).
- read a thermistor with the last two lines ( time to charge a capacitor with a thermistor in serial ) one output will give power to charge the capacitor and one input to detect full charge.
The aim is to create a robot (Dog?) wich will be the most realistic, and react with the environnement.
The only doubt I have ? Will the nxt have enough power to drive this with other classical sensor plugged and motors ?
Re: More sensors on 1 in (2 mic, 2 photoresistor) and soon more
Looks pretty cool! Want to post the schematic?
The NXT can supply about 180 ma to the sensors and motor encoders. Stock sensors use from 0 (touch sensor) to about 16 (light sensor with LED on) ma each. NXT motor encoders use 9-12 ma each. Usually I figure it's safe to draw 100ma, use 3 motors, and maybe 1 or 2 other sensors. 180ma - (12ma * 3 motors) - (16.3ma * 3 light sensors with LEDs) = 95.1ma left over, and that's assuming you are using three light sensors with LEDs on, and all three motors are plugged in.
floppi
Post by floppi »
The schematics...
The first part about PCF8591 is taken from the book : Extreme nxt
http://www.amazon.com/Extreme-NXT-Exten ... 1430224533
I want to respect the work from the author and i wonder if i can publish the schematic ?
About the other part ( mic with LM357), here is the schematic :
http://lowvoltage.files.wordpress.com/2 ... =604&h=260
Today I bought a new PCF8591 to add more input, i have a PIR sensor, motion sensor would be cool !
If the nxt Brick can not supply enough power, i will add external batteries (9V?), but I dont think it will be necessary those Ic do not need power.
floppi
Post by floppi »
I finally decided to post the entire schematic, ( nxt wires, PCF8591, LM357, photoresistor, microphone ).
I think I have added many more thing to the original schematic so i can publish it.
I put the link to the book which help me, it's enough ?
( I very recommand this book to everyone who want to build home made sensor !!! )
But, this take time to build the all schematic, and the final settings are not already done.
I will post the schematic when all is ok.
PS : with the 8574 : trying to read a charging time of a capacitor in serial with a thermistor is not possible ! To have a logic 0 on the input pin of the 8574, the output must be plugged to the ground. Leaving the output like "not connected" ( this is the case with this system ) will result in a read of a 1 logic.
I look forward to seeing it :)
floppi
Post by floppi »
ok, I abandonned the idea of motion sensor from scratch..
Unable to make it work.
So i bought a motion sensor at 18$, this motion sensor was in two parts : the detector which works on 3*1.5V battery ( exactly what I want :) ) and a second part to be plugged on a power socket to make sound when remote sensor detect something.
I separate in two the first part, the motion sensor and the remote.
I have a perfectly workable motion sensor.
( and a bonus, a remote control wich make sound... what about pluging it on the nxt for a different project ?)
SO here is my objectives :
2 * PCF8591P :
- 2 * thermoresistor
- 2 * photoresistor
- 1 * motion sensor
- 2 * mic
- 1 analog input available for ????
1 * PCF 8574 for driving 8 output ( or 8 input like 8 touch sensor !!!! )
all that on a single input of the nxt :mrgreen:
project should be done within 1 weeks.
floppi
Post by floppi »
At this stage :
- 2 * PCF8591P
- 2 * photoresistor on first PCF8591
- 2 * thermistor on first PCF8591
- 2 mic with LM357 opamp on second PCF8591
Overall current use : 5 mA !!!!!! :o :o
floppi
Post by floppi »
I just found what to do with the last remaining analog input !
I saw on the net that foam used to protect computer memories ( ram ) in packages are conductive foam, resistive value varies when you press it or just touch it !!
Add an op amp and let's go !!
Tested and it works, this will go on the head of the robot to detect petting !
floppi
Post by floppi »
Here are the schematics of first version ( 2 mic, 2 photoresistance, 2 thermistance ).
WARNING : R1 and R2 are used to terminate I2C bus, so if you plug two PCF8591 like here, you must plug only one time R1 and R2.
First PCF adresse : 0x90
2nd PCF adresse : 0x98
List of materials :
R1,R2 : 82k ohm
R3,R4,R5,R6 : 10k ohm ( 6 resistance for the two PCF8591 )
U1,U2 : PCF8591P
CTN1,CTN2 : thermistor 10k ohm
LDR1,LDR2 : photoresistance
Microphones :
I replace R5 with 82k ohm.
I do not plug C2 and C3
with one LM358 you can build two times this schematic,
For the second mic the pin are 7,6,5 instead of 1,2,3
Plug V_OUT to CH0 of U2, and 2nd V_OUT to CH1 of U2
Vcc is green wire of nxt
List of materials ( for 1 mic ) :
- 1 mic
- R1,R2,R3 : 10k ohm
- R4 : 1k ohm
- R5 : 82k ohm
- C1 : 10µF
- LM358 IC
NXC Example :
#define port S1 // sensor port 1
#define I2CAddr8591 0x90 // PCF8591 address
#define I2CAddr8591_2 0x98 // 2nd PCF8591 address
byte WriteBuf1[] = {I2CAddr8591, 0x04}; // write buffer
byte WriteBuf2[] = {I2CAddr8591_2, 0x04}; // write buffer
byte ReadBuf[]; // read buffer
int RdCnt=5; // read 5 bytes
SetSensorLowspeed(port); // make port I2C
while(true){
// Write config byte and read back 5 bytes
I2CBytes(port, WriteBuf1, RdCnt, ReadBuf);
NumOut(0,LCD_LINE1,ReadBuf[1],true); // Chan 0
NumOut(0,LCD_LINE2,ReadBuf[2]); // Chan 1
NumOut(0,LCD_LINE3,ReadBuf[3]); // Chan 2
NumOut(0,LCD_LINE4,ReadBuf[4]); // Chan 3
I2CBytes(port, WriteBuf2, RdCnt, ReadBuf);
NumOut(50,LCD_LINE1,ReadBuf[1]); // Chan 0
NumOut(50,LCD_LINE2,ReadBuf[2]); // Chan 1
NumOut(50,LCD_LINE3,ReadBuf[3]); // Chan 2
NumOut(50,LCD_LINE4,ReadBuf[4]); // Chan 3
Source :
Use of LM358 : http://lowvoltage.wordpress.com/2011/05 ... 8-mic-amp/
Use of PCF8591 : http://www.rjmcnamara.com/2010/06/extre ... torms-nxt/
Cool! Thanks for sharing!
