NXC Import File in float-array
domsel
Post by domsel »
I am trying to import a .csv file I created in Excel which is filled with float numbers.
My wish is for the numbers to be filled into a two-dimensional array.
I have several problems - alternating from not compiling to file-error -1...
Can anybody help?
Cheers
Dominik
EDIT: An example-code:
//Motor A Range: {0°,820°} X
//Motor B Range: {0°,500°} Y
//Motor C Range: {0°,-950°} Z
#import "/home/dominik/Desktop/TAIS-HiWi/test nbc/testd.csv" datad[3][2]
void move_x(float pwr, int deg)
	RotateMotorEx(OUT_A,pwr,deg,1,false,true);
void move_y(int pwr, int deg)
	RotateMotorEx(OUT_B,pwr,deg,1,false,true);
void move_z(int pwr, int deg)
	RotateMotorEx(OUT_C,pwr,deg,1,false,true);
string tmp[3][2];
float a[3][2];
float pw,b;
	tmp=FlattenVar(datad);
	UnflattenVar(tmp,a);
	pw=a[0][0];
	move_x(pw,800);
	b=a[0][1];
	Wait(b);
	move_x(pw,-800);
	pw=a[1][0];
	move_x(pw,800);
	b=a[1][1];
	Wait(b);
	move_x(pw,-800);
	pw=a[2][0];
	move_x(pw,800);
	b=a[2][1];
	Wait(b);
	move_x(pw,-800);
Re: NXC Import File in float-array
Best to post your code so we can see what you are doing.
domsel
Post by domsel »
Done. See above.
tmp is an array at your code
string tmp[3][12];
, so your asignment is faulty.
at least you will have to declare the indices of tmp.
otherwise you'd just use tmp as a simple string var
string tmp;
domsel
Post by domsel »
yes that seemed to make sense to me. I tried to follow your advice but got only this far:
Code:
//Die Verwendung mehrerer verschachtelter tasks dient nicht der Übersichtlichkeit aber der korrekten Abfolge und Verknüpfung der Bewegungen.
string tmp[3][2];
float a[3][2];
float pw,b;
	for(int i=0;i<=2;i++)
		for(int j=0;j<=1;j++)
			tmp[i][j]=FlattenVar(datad[i][j]);
			UnflattenVar(tmp[i][j], a[i][j]);
	pw=a[0][0];
	move_x(pw,800);
	b=a[0][1];
	Wait(b);
	move_x(pw,-800);
	pw=a[1][0];
	move_x(pw,800);
	b=a[1][1];
	Wait(b);
	move_x(pw,-800);
	pw=a[2][0];
	move_x(pw,800);
	b=a[2][1];
	Wait(b);
	move_x(pw,-800);
leads to:
# Status: NBC compilation failed.
# Error: Error parsing expression: datad[__main_7qG2_i_7qG2_001][__main_7qG2_j_7qG2_003]
File "/home/dominik/Dropbox/TAIS-HiWi/test nbc/portalx.nxc" ; line 32
# Error: Error parsing expression: tmp[__main_7qG2_i_7qG2_001][__main_7qG2_j_7qG2_003]
File "/home/dominik/Dropbox/TAIS-HiWi/test nbc/portalx.nxc" ; line 34
# Error: Error parsing expression: a[__main_7qG2_i_7qG2_001][__main_7qG2_j_7qG2_003]
# Error: Invalid variable argument: a[__main_7qG2_i_7qG2_001][__main_7qG2_j_7qG2_003]
# unflatten a[__main_7qG2_i_7qG2_001][__main_7qG2_j_7qG2_003], __D0main, __constVal0, __constVal0
# Error: Invalid string argument: __constVal0
5 errors during compilation
Thanks for the help so far. It's about time to leave my office now, so I will look for new answers tomorrow morning.
Cheers!
Unfortunately, the #import pre-processor directive does not work like you hoped it would. This feature lets you import a file as a raw 1 dimensional byte array containing all the bytes in the file that you import. So a file containing
HI THERE
would result in a data array defined like this:
byte data[] = {'H', 'I', ' ', 'T', 'H', 'E', 'R', 'E'};
So automatically importing a csv file into a multi-dimensional array is not supported via #import.
You might be able to use #include to insert a comma-separated list of floating point numbers into an array initializer but I am not sure that would work either. The problem there would be the requirement for { and } at each dimension level.
domsel
Post by domsel »
thank you, that helps in a way, because I know now that I am not just too silly to use the commands properly.
I will try working with three files now and then save the three resulting arrays in a two dimensional super-array :)
So long!
Cheers
Dominik
