Bluetooth problem on OSX Mountain Lion, ok in Windows 7
milzit
Post by milzit »
I have tried to follow different setup guides for configuration Bluetotth connection to the NXT, for example this: http://blog.electricbricks.com/en/2010/ ... tooth-mac/
I´m using a Macbook Pro and I´m able to pair from the Bluetooth OSX settings, and it looks paired OK. But I find nothing when I press the SCAN button in the Mindstorm software. If I do the same windows Windows 7 on the same Macbook (using BootCamp) I can scan and connect to the NXT without any problems.
Also when I select "edit serial ports" it look configured correctly with the "Dev B" as described on the guide.
Any ideas why I cannot get this to work from OSX?
