Hi all,
I'm using an EV3 and a light sensor as a very simple visual encoder for a test rig. The intent is to let it run overnight with the test rig and it have it count cycles. Unfortunately the EV3 turns itself off after ~20 minutes, even with the counter still running. Is there an automatic power-off function built into the EV3? Is it possible to disable this?
Any help would be greatly appreciated. Thanks!
EV3 automatic power off?
Re: EV3 automatic power off?
Under settings, the second item is 'sleep'. Set it to 'never'.
