EV3 BricxCC Documentation
zack-qeng
Post by zack-qeng »
Hi All,
I am wondering if there is any documentation for writing C/C++ code for the EV3 in BricxCC. More specifically dealing with how to read the sensors and send power to the motors.
Thanks,
Zack
Re: EV3 BricxCC Documentation
AFAIK there is no such thing.
Maybe you wish to have a look at Mono / C# instead:
http://www.monobrick.dk/software/ev3firmware/
but admittedly OOP is not my world...
zack-qeng
Post by zack-qeng »
Unfortunately Mono doesn't look like it will work for what I'm doing.
I don't suppose you know what the function for sending a signal to the outputs (motor ports) is/are. Or how to read from the sensor ports?
Those are the only two things that I still need to be able to do in BricxCC to get it to be able to do everything that I need it to do.
Thanks,
Zack
well, I personally don't understand anything about Mono, but maybe other users do -
or maybe you wish to post your question into the Mono forum...? The more beginners ask their questions, the better ! ;)
http://www.monobrick.dk/forums/
for autonomous robots: http://www.monobrick.dk/forums/user/mon ... irmware-2/
ps, edit,
these 2 following links I got from a member of our German forum, maybe it helps you:
https://github.com/Larsjep/monoev3/blob ... Program.cs
