ASCII
dudmaster
ASCII
Post by dudmaster »
Hello, i need a complete ASCII table of the NXT, because i have use of the check mark (used in NXT Program menu)
and i don't have the character to copy into my program. Does anyone have a copy-paste ASCII NXT table that has the check-mark?
Thanks,
DUD
2Labz.com, My Website
Re: ASCII
If all you want, is a check mark, you could just draw it with two lines, although I would as well like to see a list of NXT supported characters.
Re: ASCII
mattallen37 wrote:If all you want, is a check mark, you could just draw it with two lines, although I would as well like to see a list of NXT supported characters.
All you need to do is test them out. The values supported, AFAIK, are from 0x20 to 0x7F inclusive (32 to 127).
Here is my favourite ASCII table look up website*:
http://ascii-table.com/
* ...so far. You may start finding other good ASCII websites, and have to give up your old ones. No matter how long you've spent time together, you have to stop crying, and let it go. It's for the better for both of you.
dudmaster
Re: ASCII
Post by dudmaster »
I'v been testing them out for some time using my TextEdit program. I accidentally found this character in a .txt file that i read by using my TextEdit program.
Re: ASCII
This is the default NXT font:
The last character in this font looks a bit like a checkmark. Its ASCII value is 0x7F or 127.
dudmaster
Re: ASCII
Post by dudmaster »
How can i initialize this character to an array and/or variable?
Can you post a program?
Thanks, Dud.
Re: ASCII
dudmaster wrote:How can i initialize this character to an array and/or variable?
Thanks, Dud.
I'll assume you're talking about this:
void WasteSomeRAMandCPU(string &szOut[])
    ArrayInit(szOut, " ", 0x80-0x20+1);
    for(char charidx = 0x20; charidx < 0x80; charidx++)
        szOut[charidx-0x20] = FlattenVar(charidx);
string UseThisInstead(unsigned int idx)
    idx += 0x20;
    return(FlattenVar(idx));
    string szVar[];
    WasteSomeRAMandCPU(szVar);
    TextOut(0, LCD_LINE1, szVar[10], 0);
    TextOut(0, LCD_LINE2, UseThisInstead(10), 0);
    Wait(2000);
If I assume incorrectly, please correct me.
