NXC: WriteI2CRegister compile error
(because it's more a compiler or syntax problem, I moved this post from the Tetrix hardware thread to the software forum...)
I just tried my first Tetrix Motor Control program, but it doesn't compile!
(Bricxcc 3.3.8.9. built 3.11.2010)
// #include "nxcio.h"
void TXMotorOn(byte NXTport, byte TXmotor, char percentage)
  byte devAddr, modeReg, powerReg;
  char result;
  devAddr = (TXmotor+2)&14;
  modeReg = 0x44 + (TXmotor % 2)*3;
  powerReg= 0x45 + (TXmotor % 2);
  // NXTsensorPort, I2Caddress, 44H byte Motor_mode: 0=power control
  result=WriteI2CRegister(NXTport, devAddr, modeReg,  0);
  // NXTsensorPort, I2Caddress, 45H s/byte  Motor_power: e.g. 50 =50%
  result=WriteI2CRegister(NXTport, devAddr, powerReg, percentage);
  TXMotorOn(0, 1, 50);
  Wait(2000);
  TXMotorOn(0, 1,-50);
  Wait(2000);
  TXMotorOn(0, 1,  0);
  Wait(2000);
  while (true);
# Error: Invalid constant expression: __TXMotorOn_7qG2_modeReg_7qG2_000
File "c:\Temp\temp.nxc" ; line 15
# set __WDSC_SensorRegister, __TXMotorOn_7qG2_modeReg_7qG2_000
# Error: Invalid constant expression: __TXMotorOn_7qG2_powerReg_7qG2_000
File "c:\Temp\temp.nxc" ; line 17
# set __WDSC_SensorRegister, __TXMotorOn_7qG2_powerReg_7qG2_000
2 errors during compilation
what's wrong???
Re: NXC: WriteI2CRegister compile error
I did some experimentation and it seems that if the register is not known at compile time then it just won't work.
breaks
result=WriteI2CRegister(NXTport, devAddr, 0x45, percentage);
compiles fine.
So you need to use the standard method of I2C communication, not this short cut.
thx for your hint, Xander! I already was almost back to despair.
I will post it to the wishlist, but can you pls tell me how to rebuild the code to the standard method in the meantime?
Try this, it hasn't been tested, of course. I based the code on other stuff I've written before.
  const byte retLen = 0;
  byte modeMsg[];
  byte powerMsg[];
  char result;
  // Create the message arrays
  ArrayBuild(modeMsg, devAddr, modeReg);
  ArrayBuild(powerMsg, devAddr, powerReg, percentage);
  // Send the first message as soon as the bus is ready
  while ((I2CCheckStatus(NXTport) == STAT_COMM_PENDING) && (I2CCheckStatus(NXTport) != NO_ERR)) Yield();
  if(I2CWrite(NXTport, retLen, modeMsg) != NO_ERR)
    return;
  // Send the second message when the first one is done
  if(I2CWrite(NXTport, retLen, powerMsg) != NO_ERR)
    return;
  Wait(2000);
  Wait(2000);
  TXMotorOn(0, 1,  0);
  Wait(2000);
  while (true);
The first message needs to built up like this:
ArrayBuild(modeMsg, devAddr, modeReg, 0);
My bad.
This code should do what you need:
long MyWriteI2CRegister(byte port, byte address, byte register, byte regvalue) {
  byte msg[];
  ArrayBuild(msg, address, register, regvalue);
  while ((I2CCheckStatus(port) == STAT_COMM_PENDING) && (I2CCheckStatus(port) != NO_ERR)) Yield();
  return I2CWrite(port, retLen, msg);
Again, not tested :)
thx a lot again, Xander.
I tried the new code with the new ArrayBuild,
it compiles without error,
mux power is on,
the NXT screen says "running"
- but nothing happens. :cry:
I surely will therefore have to wait for John's Tetrix implementation.
acc. to your
will it be possible to pass also a int or a long as a regvalue (e.g., for passing encoder values)?
doc-helmut wrote:will it be possible to pass also a int or a long as a regvalue (e.g., for passing encoder values)?
Nope, as long as NXC doesn't support function overloading it can't be done with a single function name.
ok, thx, but I must admit: it is even much harder than I thought with the I2C motor program for Tetrix
But that's not a WriteI2CRegister compile issue any longer.
- thread can be closed -
I am fixing this problem in WriteI2CRegister so that you can pass in a variable or a constant.
