NXT-G color sensor block's sliders are locked!
haydenstudios
Post by haydenstudios »
Hello, I am an NXT-G user, I consider myself an expert with some the the advanced programs that I have written, but I have had one problem that has so far not troubled me yet due to my lack of need for the current situations in which my robots have been placed so far, but it would still be very nice to have this problem solved. So, the sliders in the color sensor's configuration panel can be dragged across a full rainbow of colors, unfortunately, these sliders are fixed so that they can only reside at seven different positions. Does anyone out there know some kind of hack that can get the raw value of the color sensor in NXT-G, or perhaps unlock these sliders? I remember posting this only a few days before NXTasy crashed, but I never got to see any replies... :cry: . OH well! :) Please give me any info you can.
-Hayden
Re: NXT-G color sensor block's sliders are locked!
If you want access to the full functionality of this sensor, you will need to use either NXC or some other programming language like ROBOTC or Lejos.
Post by hassenplug »
I posted an NXT-G block that has outputs for red, green, and blue. It's listed as "Color Range Block".
http://www.teamhassenplug.org/NXT/NXTGAdditions.html
haydenstudios
hassenplug wrote:I posted an NXT-G block that has outputs for red, green, and blue. It's listed as "Color Range Block".
Thanks for trying, but for some reason, when I try to open the folder in the block import and export wizard, nothing happens. The block import and export wizard has worked flawlessly for me on the Legacy blocks, the Battery Level block, the HiTechnic IRLink RCX communication block, and the HiTechnic Accelerometer sensor block. But for some reason it doesn't seem to work for your color range block. Please help!
-Hayden
Well, it looks like it's not going to work. I have too many different versions of stuff on my computer.
Sorry to get your hopes up.
palbarede
Post by palbarede »
I am an new to Lego Mindstorms so I may miss basic points, although I am an experienced programmer in other areas.
I have a problem with the color sensor, related to haydenstudios's.
Initially the sliders are around yellow and I cannot set them to a other positions except around black (first and second ticks among seven possible).
Mac OS X.6.6.
Lego Mindstorms NXT v2.0
2009-03-25-1341
hassenplug's block would probably solve my problem, if it worked.
There are a few other painful bugs in Lego Mindstorms NXT.
-->>Is it worth reporting to Lego ?
Maybe no, as the software has not been updated for nearly two years now. They seem to provide minimal service.
-->> Is it possible to hack a text file somewhere to define the color ?
I am ready to shift to a text-based interface. I have Hansen's book on NBC/NXC with me. It seems to be OK for me because I would not like the graphical interface, even bug free, because it is slow to program.
Thanks for advice.
