Idea: Visual NXC
sidneys1
Idea: Visual NXC
Hey all,
First off, I'm not even sure if I can do this. My skill at programming an IDE are as of yet untested. BUT, if I could manage to create a "Visual NXC" (aka, a program like NXT-G or Enchanted that outputs *.nxc code files), what kind of features would you want to see?
Right now the concept is for less of an IDE and more of a supplement to BricxCC, somewhat like the Class Designer in MSVS... It'd let you lay out the structure of your programs far more easily than in a textual IDE.
Again, no promises.. I'm just trying to see what the community would want, while I do some research into whether this is actually possible or not.
Have a nice day,
~Sidneys1
Have a nice day,
~Sidneys1
Re: Idea: Visual NXC
I personally don't support the idea. NXT-G is for those who want graphics, and there are already 2 versions of that; retail and education. There is also (as you mentioned) Enchanted, but also robolab. That is 3-4 graphical computer programs that are specifically for programming the NXT. Do we really need another? I like the idea of outputting/compiling as NXC code, but is it really necessary?
This idea reminds me a bit of RCX Code. Despite the terrible inabilities of it, it would save the files as a C type file. You would build with blocks, and in the background, it would be building in C (or something like C, I haven't looked at it much). When you would go to download it, I guess that is when it would compile and download the "C" program.
I see so many questions on this and other forums on the same themes, time and time again.
I think you would get far more support if you avoided starting yet another language and instead set up a library of basic NXC codes or macros.
Segments such as accessing the various sensors, opening files, etc which could be incorporated into user's programs would be ideal and save more time than having to keep up with another programming environment.
This could be expanded all the time and would serve as a repository for reference to avoid the continual re-invention of the computing wheel.
sidneys1
Just to clarify, for all intents and purposes, NXT-G Retail and Edu are identical - the only difference that I am aware of is the built in "Robot Center" building instructions. RoboLab is ancient, and pretty pricey ($100USD+ for a single license, according to Lego Edu). Enchanted, while amazing, is only usable by those willing to switch over to LeJOS, preventing BricxCC and NXT-G use. This does not leave 2-4 graphical IDE's, but one: NXT-G. And even that isn't free. This would give graphical programmers an opportunity to have a free IDE for use with the standard Lego FW.mattallen37 wrote:I personally don't support the idea. NXT-G is for those who want graphics, and there are already 2 versions of that; retail and education. There is also (as you mentioned) Enchanted, but also robolab. That is 3-4 graphical computer programs that are specifically for programming the NXT. Do we really need another? I like the idea of outputting/compiling as NXC code, but is it really necessary?
An excellent point, but it's not a language.. It's merely a re-representation of NXC. It would essentially be a 'library' of basic NXC codes and macros: a single 'block' could represent dozens of lines of code, and it would organize it neatly, then present the user with the *.NXC files for further manual code additions.h-g-t wrote:I you see so many questions on this and other forums on the same themes, time and time again.
However, I am interested in what you say about an NXC library to wrap common NXC routines. Could you elaborate more on what you would want to see in a package like that?
Have a nice day,
~Sidneys1
NXT-G may cost money, but it is included in every NXT retail set. That means that probably at least 99% of NXT owners have at least one NXT-G CD. The other 1% (or whatever) obviously got the set second hand, or only have an edu set. What about the many people (like most of us here) that don't even use NXT-G? I have probably 3 or 4 NXT-G CDs, and I only ever run NXT-G on one computer, and at most 1 time a month (to test things). I doubt there is a single NXT owner, that wishes to have NXT-G, and has no way of accessing it. If there is anyone, they should be able to learn another language for programming. If Lego only supplied a text based programming language, imagine how many more people would know how to program using something besides blocks. I like the concept of your idea, but I wouldn't invest much into something like that. If someone knows enough to see the advantage of a language like you suggest, they should know enough to program in NXC. If the idea of your suggestion isn't to allow modification of the NXC code with something like BCC, then what is wrong with NXT-G? I like you idea, I just think it's pointless.
Yeah, it's a nice idea, but I believe the "cost" of undertaking such a project heavily outweighs any benefits to the community. That said, it'll be a great "exercise" for you to develop your programming skillz even further.
It would be a nice transition from graphical programming with NXT-G to NXC for many, though. One I can think of that might like this is nxtreme, who wishes to learn NXC sometime in the near future, but still prefers NXT-G due to the "learning curve" NXC has. (Not much of a "learning curve" if you've programmed in C before, though.)
If I sound too formal, blame it on my reading of Book 3 of LOTR, once again.
P.S. What would "Not Entirely Unlike NXC" be?
I very heavily agree with muntoo here. While I think that it would be used somewhat, the "cost" might be too high. You probably won't have a huge user group, maybe 5-10% of NXT users max, and developing something like this would take months, if not years, if you wanted it to be rock solid. I'm not trying to say it's a bad idea, quite on the contrary in fact, but just that it's probably something that would never "catch" if you get my point.muntoo wrote:Yeah, it's a nice idea, but I believe the "cost" of undertaking such a project heavily outweighs any benefits to the community. That said, it'll be a great "exercise" for you to develop your programming skillz even further.
However, I like the idea Matt has. I think it'd fit in to your plans of helping newer (or less experienced) users get started with something more advanced like NXC. Creating a basic library of NXC code macros (or "blocks") would help new users to jump in to NXC and start creating working programs faster, then find out what's going on behind the scenes later on (just like Arduino).
Thanks for using me as an examplemuntoo wrote:It would be a nice transition from graphical programming with NXT-G to NXC for many, though. One I can think of that might like this is nxtreme, who wishes to learn NXC sometime in the near future, but still prefers NXT-G due to the "learning curve" NXC has. (Not much of a "learning curve" if you've programmed in C before, though.)
I know that this is C (or Not eXactly C
Actually, NXC commands are very straight forward for the most part. Just as easy as Arduino. They are different of course, as you don't write the IO pins high and low or read them, directly (different set of commands). It is very much the same concepts though.nxtreme wrote:...Creating a basic library of NXC code macros (or "blocks") would help new users to jump in to NXC and start creating working programs faster, then find out what's going on behind the scenes later on (just like Arduino)...
The one "problem" I have with NXC is that commands aren't quite as intuitive as something like Picaxe Basic.
I know that this is C (or Not eXactly C) so commands aren't 'sposed to be spelled out for you like with Basic, but it'd take me a couple days to learn what the basic commands are, whereas when I started learning Picaxe Basic, it was more of a "just jump in" experience. And I usually spend about an hour a week actually programming (for my NXT, about two or three times that for Picaxe) so for now, NXC isn't a high priority.
For me, I would only normally program with NXT-G a couple hours a week. Since I switched to NXC, the possibilities are so endless, and it is so headache/glitch-free, that I program more like 5-20 (sometimes over 40) hours a week (depending on what I'm working on of course).
Err... no. In my opinion, 2K+ users would be "large".nxtreme wrote:You probably won't have a huge user group, maybe 5-10% of NXT users max
Of course, I think it's more like 50% potential NXC users finding Visual NXC useful. Existing "experienced" NXC users, maybe around 1%.
Of course, those are just my guesses. But many a great tool's development has been hindered by idiots like me.
sidneys1
Exactly my point - it would be an excellent transitional language. It would allow users to 'build' their program graphically, but to compile they still need to look at the 'code behind the blocks'. As for being formal, Muntoo, I just started re-reading Charles Dicken's "Our Mutual Friend", so pardon my Dickensian englishmuntoo wrote:Yeah, it's a nice idea, but I believe the "cost" of undertaking such a project heavily outweighs any benefits to the community. That said, it'll be a great "exercise" for you to develop your programming skillz even further.
I suppose "Not Entirely Unlike NXC" would be "NEU-NXC", (new NXC) or "Not Entirely NXC": "NotE NXC" (note as in shorthand) Those could be technical names... I still prefer "Visual NXC" as the face-name; more descriptive and asthetic.
Also, I'm a faster programmer than you may suppose - I already have most of the UI done for the proof-of-concept I'm making
I'm also liking this NXC macro/wrapper library idea... I may look into it
Have a nice day,
~Sidneys1
P.S. Pardon my spelling, the computer I'm using doesn't have IEspell
