The Knight- A platformer
nxtboyiii
Post by nxtboyiii »
Introducing...... The Knight!
Version 2
THE GAME:
This is a game where you play as a knight
INSTRUCTIONS
NXT buttons to move, touch sensor to stab- if enemies are next to you then you lose life. TNT kills you, fire takes away life
If touch sensor 1 is pressed and the center button is pressed then it will pause and it will display your money and a map of the game in lower left corner(Only displays solid objects, not water, enemies, fire, etc).
So far no goal
You can make your own maps by changing the text file that is called "map.txt" the number on the top of the map is the map height. Replace that with the height yours is(count how many tiles it is going up). The different tiles are inside the program where all the #defines are with the capital letters like the BRK and AIR. Once you save the map, load it on to your nxt. Make sure it is called map.txt
REQUIREMENTS
An NXT(Duh)
A touch sensor into port 1
CREDIT
bag of money and TNT and orc- sidneys1 from mindboards.,net
ladder- me
broken brick wall and brick wall- turiqwalrus from omnimaga.org
Snake- stryker001 from mindboards.net
gravestone and both water sprites- Ashbad from omnimaga.org
fire and knight jumping and broken stone wall(edited from ZippyDee's stone wall)- yunhua98 from omnimaga.org
knight standing still and knight stabbing and stone wall and evil fish- ZippyDee from omnimaga.org
Any ideas would be appreciated. :)
The Knight!!.zip
(6.93 KiB) Downloaded 537 times
haydenstudios
Re: The Knight- A platformer
Post by haydenstudios »
Can we download it? I'm not seeing any attachment. Your game sounds cool by the way.
-Hayden
nxtboyiii
Post by nxtboyiii »
Just added it
haydenstudios
Alright, :) Maybe I'll have a go at it some time from now when I've finished a project that I'm currently working on (has nothing to do with NXT).
-Hayden
nxtboyiii
Post by nxtboyiii »
Anyone have any ideas/comments/complaints/help?
Should I change/remove/add anything?
nxtboyiii
Post by nxtboyiii »
Now the maps can be made on a separate text file!
themindstormman
Post by themindstormman »
i'm trying to download it cause i'm dying to play it
Themindstormman3141
NXT FOR ALL
nxtboyiii
Post by nxtboyiii »
why cant you download it?
themindstormman
i'm new to nxc and it always says compile/ download failed
Themindstormman3141
NXT FOR ALL
nxtboyiii
Post by nxtboyiii »
Maybe you should delete stuff off of your nxt. Whats the error say?
