NBC Compiler Help!
bungeshea
NBC Compiler Help!
Post by bungeshea »
I am trying to set up a NBC compiler that I downloaded from the BricxCC website on a portable hard drive. After consulting "Power Programming, Second Edition" I found out that to set up an NBC compiler by typing the following into the Command Prompt, if application is in the C:\nbc directory.
I want to set up the compiler on a portable hard drive, let's say it's plugged into the H:\ Drive. What do I type into the CMD to assess the compiler?
Re: NBC Compiler Help!
So... you want to compile like this:
nbc "%USERPROFILE%\Desktop\myprogram.nxc"
And make it portable? I'm confused...
Users browsing this forum: Semrush [Bot] and 37 guests
