[NXC][Bug] Decrementing char in string
The following code doesn't compile:
    string name = "MineCraft";
    --name[3];
The following code does:
    name[3]--;
Is this a bug, or do my eyes C wrong?
If there's any ambiguity, please pretend that there are () brackets around name[3].
Re: [NXC][Bug] Decrementing char in string
I would call this a not exactly C limitation. My support for prefix increment and decrement are kind of hacks. You may have to live with this unless a simple solution jumps out at me.
Did you verify that the second case actually generates functioning code or does it just compile but not work?
afanofosc wrote:Did you verify that the second case actually generates functioning code or does it just compile but not work?
It looks like it generates the correct NBC code, but I'll test if it actually works tommorow:
dseg	segment
	__signed_stack_001main	sdword
	__unsigned_stack_002main	dword
	____initialize_global_data_return	byte
	__constVal1	sbyte	1
	__constStr0009	byte[]	'MineCraft'
	__main_7qG2_name_7qG2_000	byte[]
	__strbufmain	byte[]
dseg	ends
thread main
	subcall __initialize_global_data, ____initialize_global_data_return
	strcat __strbufmain, __constStr0009
	mov __main_7qG2_name_7qG2_000, __strbufmain
	set __signed_stack_001main, 3
	index __unsigned_stack_002main, __main_7qG2_name_7qG2_000, __signed_stack_001main
	sub __unsigned_stack_002main, __unsigned_stack_002main, __constVal1
	replace __main_7qG2_name_7qG2_000, __main_7qG2_name_7qG2_000, __signed_stack_001main, __unsigned_stack_002main
	exit -1, -1
endt
subroutine __initialize_global_data
	subret ____initialize_global_data_return
ends
That code definitely should work. Thanks for checking. I'll take a peek at how my prefix decrement/increment code works and see if it could be expanded to work with things other than simple variables.
ricardocrl
Post by ricardocrl »
By the way, what should happen with a prefix decrementing/incrementing? I've never seen that in C. Is it from C++ or something other than pure C?
bullestock
Post by bullestock »
ricardocrl wrote:By the way, what should happen with a prefix decrementing/incrementing? I've never seen that in C. Is it from C++ or something other than pure C?
Both postfix and prefix increment/decrement is part of Standard C (and Standard C++).
See http://en.wikipedia.org/wiki/Increment_ ... _operators for details.
yes, prefix is often used for assignings after increment while postfix assignes before incrementing:
j=i++; // assignes (old) i before incrementing
j=++i; // assignes (new) i+1 (after incrementing)
Maybe a "real" ANSI C compiler that compiles directly to bytecode would make it sometimes easier to use ANSI C syntax... ;)
ricardocrl
It seems confusing to the eyes, to see that kind of operations (y = ++x;), because it's two at "once". I normally only use "x++;" for instance.
Is there any advantage of writing "y = ++x" instead of using just "x++;" plus "y = x", besides making the code smaller?
ricardocrl wrote:Is there any advantage of writing "y = ++x" instead of using just "x++;" plus "y = x", besides making the code smaller?
Not really. It all becomes the same assembly code in the end.
BTW, it's better practice to use ++x; instead of x++;.
I'm not sure if the both following do the same (in C, not in C++):
for(int i = 0; i < 42; i++) {printf("%d\n", i}
// vs.
for(int i = 0; i < 42; ++i) {printf("%d\n", i}
(not at home, can't test it)
