NXC code to NBC code
nxtboyiii
Post by nxtboyiii »
Can someone convert this NXC code into NBC code so it will run faster?
I will just use the asm inside the NXC code.
Here it is:
  for(int c=floor(xadd/-16); c < ceil(xadd/-16)+6; c++)
   CircleOut(x+8,y+8,8,DRAW_OPT_FILL_SHAPE);
   for(int d=floor(yadd/-16); d < ceil(yadd/-16)+4; d++)
     var[0]=map[c][d].x;
     var[1]=map[c][d].y;
     GraphicOutEx(c*16+xadd,d*16+yadd,"gmtilesb.ric",var);
Thanks,
Re: NXC code to NBC code
Always optimize the algorithm first (like Knuth!), then the code.
nxtboyiii
Post by nxtboyiii »
Can you post some NBC code of the NXC code in NBC?
I don't know about NBC, but here's a slightly more micro-optimized version:
// These remain "constant"
int maxval_x = ceil(xadd / -16) + 6;
int maxval_y = ceil(yadd / -16) + 4;
int init_c = floor(xadd / -16); // This one's actually unnecessary... But let's keep it consistent.
int init_d = floor(yadd / -16);
int circle_x = x + 8;
int circle_y = y + 8;
int init_c2 = (init_c << 4) + xadd; // init_c << 4 is the same as init_c * pow(2, 4) or init_c * 16
int init_d2 = (init_d << 4) + yadd;
// Relative/Delta Steps
int c2 = init_c2;
int d2 = init_d2;
CircleOut(circle_x, circle_y, 8, DRAW_OPT_FILL_SHAPE);  // WHY do you keep redrawing this??
for(int c = init_c; c < maxval_x; ++c)
    d2 = init_d2;
    for(int d = init_d; d < maxval_y; ++d)
        var[0] = map[c][d].x;
        var[1] = map[c][d].y;
        GraphicOutEx(c2, d2, "gmtilesb.ric", var);
        d2 += 16; // Take a "delta step".
    c2 += 16; // Take a "delta step".
Converting to NBC doesn't magically make it faster. Sure, NXC compiles the for-loops as fail-safe for every case (this could be optimized slightly), but you should really look at the actual algorithm. (In this case, I admit that it may be harder to find a "better" algorithm.)
A few micro-optimization tricks for bottlenecks;
  • Are you reevaluating unchanging values? If so, put them in a temporary variable. (Such as maxval_x.)
    • If you look at the NBC code for CircleOut(), you'll see that it's copying the values to a DrawCircleType struct every time. Spiller did something similar in his Bezier Curve program when he also took the sacred route of NXC->NBC. What I recommend instead: using the SysDrawCircle() function directly in your NXC code. Same with SysDrawGraphicEx().
  • Notice any patterns? Can you change variables' values using relative/delta steps, instead of "absolute evaluation" (mathematicians love the "absolute" stuff, but theoretical computer scientists don't).
Here it is with the Sys stuff (post under construction):
int c2 = init_c2;
int d2 = init_d2;
// Drawing stuff
DrawCircleType dcArgs;
DrawGraphicType dgArgs;
// This is part of the code is unnecessary, unless you're putting it in a loop. I'll leave it here anyways, though.
dcArgs.Center.X = circle_x;
dcArgs.Center.Y = circle_y;
dcArgs.Size = 8; // radius
dcArgs.Options = DRAW_OPT_FILL_SHAPE;
SysDrawCircle(dcArgs);
// This part IS necessary.
dgArgs.Filename = "gmtilesb.ric";
ArrayInit(dgArgs.Variables, 0, 2);
// If that previous line doesn't work, use this instead:
// ArrayBuild(dgArgs.Variables, 0, 0);
dgArgs.Options = 0;
    dgArgs.Location.X = c2;
    d2 = init_d2;
        // GraphicOutEx(c2, d2, "gmtilesb.ric", var);
        dgArgs.Location.Y = d2;
        dgArgs.Variables[0] = map[c][d].x;
        dgArgs.Variables[1] = map[c][d].y;
        SysDrawGraphic(dgArgs);
Again, micro-optimizations make your code less readable and less maintainable. If you're sure that your code is causing slowdowns, and you're not going to be modifying it any time soon... well, I guess it's OK.
nxtboyiii
Post by nxtboyiii »
Wow. :shock: Thats a lot of stuff you said! Thanks muntoo!! :D
You are really experienced with this!!
Actually, variables xadd, yadd, circlex,and circley DO change. They are not constant. Thats a good idea to put the constants like the drawing functions before the loop so they are not repeated.
BTW, I keep redrawing the circle because the GraphicOutEx overwrites it.
Thanks!! :)
nxtboyiii wrote:Actually, variables xadd, yadd, circlex,and circley DO change. They are not constant.
By that, I meant "constant" in the for-loop. As long as you don't modify them inside the for-loop, it's OK.
nxtboyiii wrote:BTW, I keep redrawing the circle because the GraphicOutEx overwrites it.
Aha! :) That's one thing you can optimize. Why don't you put CircleOut() after the for-loop? Is there any specific effect you're trying to achieve? Can the same effect, or another appropriate effect, be done less resource-intensively?
As muntoo said, it is better to optimize the algorithm first.
In the code you provide, the GraphicOutEx() function (or the sys version for that sake) is probably what takes the most time. So if you need to call it a lot of times, it might be limited to how fast it can redraw. (That is why I started using RIC fonts where I could instead.)
Anyway, the stuff you really want to avoid is array handling, or more specifically, getting values out of an array.
I will have to leave for now, but if you would like to present a working program it would be easier for us to help optimizing it. Especially, what does the map[][] array contain and how is the RIC file constructed?
Whenever you use GraphicOutEx(), your program:
  • [Re-]Reads the RIC file into a temporary buffer
  • [Re-]"Parses" it
  • Draws new tile
The first one could be eliminated by using GraphicArrayOutEx():
byte ric_gmtilesb_data[];
void ric_init()
    byte handle;
    unsigned int fsize;
    OpenFileRead("gmtilesb.ric", fsize, handle);
    ReadBytes(handle, fsize, ric_gmtilesb_data);
    CloseFile(handle);
    // Run ONCE.
    ric_init();
    // Code here
    GraphicArrayOutEx(x, y, ric_gmtilesb_data, vars, DRAW_OPT_NORMAL);
The second one could be eliminated using SCR_File_Lib, but unfortunately, I don't think the blitting is as fast as the GraphicArrayOutEx() (which uses firmware opcodes, or something like that), so I wouldn't recommend it... :(
nxtboyiii
Post by nxtboyiii »
The map[][] is a 2D array of a structure that has these variables:
byte x;
byte y;
bool sld;
The RIC file is constructed by using a bunch of 16x16 pictures. The Copybits has the input of the x and y of what 16x16 image is currently drawn.
I don't know how to use the ric data!!
nxtboyiii wrote:I don't know how to use the ric data!!
As I showed you in the code sample above, all you need to do is put ric_init(); once at the beginning of your code. Then, use GraphicArrayOutEx(x, y, ric_gmtilesb_data, vars, DRAW_OPT_NORMAL); instead of GraphicOutEx(x, y, "gmtilesb.ric", vars, DRAW_OPT_NORMAL);.
