Lpub 4.0.0.4 anyone?
haydenstudios
Hi there, I hope that there is someone on this forum that uses the LDraw system of tools, cause that's most likely the kind of person that can help me. I am running Lpub 4.0.0.1, and I am having trouble loading LDraw models with Lsynth synthesises, because I get some error. With a little bit of research, I found that Lpub version 4.0.0.4 fixes this problem, and that Kevin Clague forgot to add a certain meta command. Unfortunately, I cannot seem to find the latest version of Lpub. All of the links to it that I've found through several google searches have been broken. Could someone perhaps attach the install file for Lpub 4.0.0.4? Thanks in advance.
-Hayden
Re: Lpub 4.0.0.4 anyone?
Seems that his web server is down, so not much to do there.
However I googled after the filename (from one of the broken links) and found it on SourceForge. So you can download it there, it seems the latest version is 4.0.0.11: SourceForge project page
I haven't used the program in a long time though so perhaps this is the opportunity to start making some instructions : )
haydenstudios
Well, it's now working a little bit better, but it's far from fixed. I receive no error, but heres what I get once I get to the step where the wires should show up.
-Hayden
