Often I use text and number display functions to debug programs. I also use them a lot for NXT -> human interface in stable programs. I have recently been doing more with floating point numbers, and have seen several things I don't care for.
Here is a scenario:
I have a thermometer that is precise to about 0.02 degrees. I want to display the number in floating point, but I don't want it to read "24.1284", I want it to drop x number of exponents, so it will display "24.1". What I have been doing is calculating the temperature in floating point, multiplying by 10, setting it to a int, then setting it back to a float, and dividing it by 10. Sure, this makes it display "24.1", but when it is 24.0, it displays "24", which isn't what I want. That ".0" is very significant, and I want it displayed.
What I need to do is convert the number into a string and then display it as text. NumToStr works fine, but it drops exponent 0's, or anything in or beyond the 10,000th's place.
How do I do this? I came up with a clumsy function that does basically what I want, but I want to know how to do it "properly".
NXT text and number displaying
Re: NXT text and number displaying
You use
If you want to store it in a string, use
Again, not sure if this actually works in NXC.
I really should figure this out for C++. All I can remember is that there's
printf() in C. Not sure how much support NXC has for this, though:
float x = 24.1284;
printf("%.1f", x);sprintf():
float x = 24.1284;
string s = "";
sprintf(s, "%.1f", x);
TextOut(0, 0, s, 0);I really should figure this out for C++. All I can remember is that there's
stringstream, and a whole bunch of other "flags"...Commit to LEGO Mindstorms Robotics Stack Exchange:
I'd indeed suggest printf() just as muntoo did. But there's also FormatNum(). You can look up the format strings in any C documentation, but you'll have to try out what NXC supports (I just have a nice link handy which happens to be for MATLAB, but the format specifiers should be the same). Maybe the %g is interesting for you, it should output significant digits of a float.
but that's not great either.
I currently use Qt's QString class, with the .arg() function, and I love it every day
. Especially as it takes care of Unicode once and for all (let's hope) and has also methods like .toStdStr() to convert to other formats...
Yep, there are various stringstream examples. But I honestly got very annoyed with it. I then came accrossmuntoo wrote: I really should figure this out for C++. All I can remember is that there'sstringstream, and a whole bunch of other "flags"...
std::cout.precision(n);
Thanks both of you
I am now able to do what I want.
I normally use this:
this wrap around FormatNum is exactly the same as what NXC does with it's printf macro.
you may use numbers (integer, fp) formatted like in ANSI C, but as a substitute to "\n" you may print at (x,y) like with NumOut or TextOut:
advantage: you need not to clear the line to avoid "overwriting" garbage printing shorter numbers after longer ones.
for strings you may write - although it is sometimes not correctly interpreted by the firmware;
but if it should be faulty sometimes for strings you can use a workaround: pass your string by the Formatstring
http://www.cplusplus.com/reference/clib ... io/printf/
http://en.wikipedia.org/wiki/Printf
TextOut(_x, _y, sval1); \
}you may use numbers (integer, fp) formatted like in ANSI C, but as a substitute to "\n" you may print at (x,y) like with NumOut or TextOut:
printf1(0,40, "%5.2f", fpvar); // OR: printf1(0,40, "var=%5.2f", fpvar);
printf1(0,32, "%10d", longvar); // OR: printf1(0,32, "var=%10d", longvar);
printf1(0,24, "%06x", intVarAsHex); // OR: printf1(0,24, "var=%06x", intVarAsHex);
printf1(0, 8, "%s", stringvar);but if it should be faulty sometimes for strings you can use a workaround: pass your string by the Formatstring
printf1(0,0, "write your string constant or variable", 0);http://en.wikipedia.org/wiki/Printf
string sval1=FormatNum(_format1, _value1); \
int i=1000;
long l=87654321;
float f= 123.45678;
string msg="HUG ME!";
printf1(0,56,"%6d", i); // 6 digits, rest space (%i = %d)
printf1(0,48,"0x%04x",i); // 4 digits hex notation, rest Zeros + "0x" prefix
printf1(0,40,"%10d", l); // 10 digits, rest space
printf1(0,32,"%7.2f",f); // 7 digits including 2 decimals, rest space
printf1(0,16,"%s", msg); // string output
while(1);
