NCX: ArrayMax, ArrayMin: unexpected values
hi,
I have
 float x[256], y[256], xmax, ymax, xmin, ymin;
all arrays have already values of [-0.5...+0.5] (out of a FFT calculation).
If I calculate the ArrayMax or ArrayMin, I always get 0 (zero) ...!
  xmax=ArrayMax(x, NA, NA);
  xmin=ArrayMin(x, NA, NA);
  ymax=ArrayMax(y, NA, NA);
  ymin=ArrayMin(y, NA, NA);
  NumOut(0,56, xmax); // all zeros!
  NumOut(0,48, xmin);
  NumOut(0,40, ymax);
  NumOut(0,32, ymin);
what is faulty?
Re: NCX: ArrayMax, ArrayMin: unexpected values
Don't ArrayMax and ArrayMin return an integer? If your values are no more than .5, and no less than -.5, then doesn't it stand to reason that you would only get 0?
Just use this:
float ArrayMaxf(float &src[], unsigned int idx = NA, unsigned int len = NA)
    if(len == NA)
        len = ArrayLen(src);
    if(len == 0)
        return(0xFFFFFFFF);
    float fmax = src[0];
    unsigned int offset = idx + len;
    for(unsigned int i = idx; i < offset; ++i)
        fmax = max(fmax, src[i]);
    return(fmax);
mattallen37 wrote:Don't ArrayMax and ArrayMin return an integer? If your values are no more than .5, and no less than -.5, then doesn't it stand to reason that you would only get 0?
the definition says "variant", not "int or "long"
variant ArrayMax  ( const variant &  src[],
  unsigned int  idx,
  unsigned int  len
Is this a bug?
muntoo,
the values of ArrayMaxf are faulty - they show 0.182 although max is about 0.3.
Min is about -0.3
for ArrayMinf is doesnt work at all
#define min(a,b) (a<b?a:b)
#define max(a,b) (a>b?a:b)
    if(len == NA)
    if(len == 0)
        return(0xFFFFFFFF);
    return(fmax);
float ArrayMinf(float &src[], unsigned int idx = NA, unsigned int len = NA)
    if(len == NA)
    if(len == 0)
        return(0xFFFFFFFF);
    float fmin = src[0];
        fmin = min(fmin, src[i]);
    return(fmin);
This is the complete test code:
// Fast Fourier Transformation for NXT
// version 1.0ß
// source for NXC
// tested with BricxCC 3.3.8.10
// orig. ANSI C source:
// http: //read.pudn.com/downloads92/sourcecode/graph/360640/work3/fft2.h__.htm
// modified by HaWe 2011
// user interface (display list + program control)
// BtnLeft  < scroll back/up array lines
// BtnRight > scroll fwd/down array lines
// BtnExit    toggle end/start of array
// BtnCenter  OK / quit
// IO functions
char LCDline[]={56,48,40,32,24,16,8,0};
  TextOut(_x, _y, sval1); \
inline bool btnhit(){
   return ( ButtonPressed(BTN1, false) || ButtonPressed(BTN2, false)
         || ButtonPressed(BTN3, false) || ButtonPressed(BTN4, false));
// math
    if(len == NA)
    if(len == 0)
        return(0xFFFFFFFF);
    return(fmax);
    if(len == NA)
    if(len == 0)
        return(0xFFFFFFFF);
    return(fmin);
// FFT
const int ArrLen=256;
float x[ArrLen], y[ArrLen];
int FFT(int dir)
   long  nn,i,i1,j,k,i2,l,l1,l2;
   float c1,c2,tx,ty,t1,t2,u1,u2,z;
   /* Calculate the number of points */
   int m= log(ArrLen)/log(2);
   nn = 1;
   for (i=0;i<m;i++)
      nn *= 2;
   /* Do the bit reversal */
   i2 = nn >> 1;
   j = 0;
   for (i=0;i<nn-1;i++) {
      if (i < j) {
         tx = x[i];
         ty = y[i];
         x[i] = x[j];
         y[i] = y[j];
         x[j] = tx;
         y[j] = ty;
      k = i2;
      while (k <= j) {
         j -= k;
         k >>= 1;
      j += k;
   /* Compute the FFT */
   printf1(0,LCDline[0],"%s", "Computing FFT... ");
   c1 = -1.0;
   c2 = 0.0;
   l2 = 1;
   for (l=0;l<m;l++) {
      printf1(0,LCDline[1],"%d", l);
      l1 = l2;
      l2 <<= 1;
      u1 = 1.0;
      u2 = 0.0;
      for (j=0;j<l1;j++) {
         for (i=j;i<nn;i+=l2) {
            i1 = i + l1;
            t1 = u1 * x[i1] - u2 * y[i1];
            t2 = u1 * y[i1] + u2 * x[i1];
            x[i1] = x[i] - t1;
            y[i1] = y[i] - t2;
            x[i] += t1;
            y[i] += t2;
         z =  u1 * c1 - u2 * c2;
         u2 = u1 * c2 + u2 * c1;
         u1 = z;
      c2 = sqrt((1.0 - c1) / 2.0);
      if (dir == 1)
         c2 = -c2;
      c1 = sqrt((1.0 + c1) / 2.0);
   /* Scaling for forward transform */
   if (dir == 1) {
      for (i=0;i<nn;i++) {
         x[i] /= nn;
         y[i] /= nn;
   printf1(0,LCDline[3],"%s", "FFT ready!");
   return(1);
void FillArray1() {
  int i;
  for (i=0; i<ArrLen; ++i) x[i]=1;
  for (i=0; i<ArrLen; ++i) y[i]=0;
void FillArray101(){
  int i;
  for (i=10; i<20; ++i) x[i]=0;
void FillArraySin() {    // single sin period: wavelength=32
  int i;
  for (i=0; i<ArrLen; ++i) x[i]=sin(i*PI*3600.0/(310.0*180.0));
void FillArraySin2() {    // double sin periods: wavelength=16
  int i;
  for (i=0; i<ArrLen; ++i) x[i]=sin(i*PI*3600.0/(155.0*180.0));
void ExtremizeArray() {
  int i;
  float xmax, ymax, xmin, ymin;
  xmax=ArrayMaxf(x, NA, NA);
  xmin=ArrayMinf(x, NA, NA);
  ymax=ArrayMaxf(y, NA, NA);
  ymin=ArrayMinf(y, NA, NA);
  NumOut(0,56, xmax);
  NumOut(0,48, xmin);
  NumOut(0,40, ymax);
  NumOut(0,32, ymin);
  while (!btnhit());
  for (i=0; i<ArrLen; ++i) {
    if ((x[i]>0) && (x[i]<=xmax/10))  x[i]=0;
    if ((x[i]<0) && (x[i]>=xmin/10))  x[i]=0;
    if ((y[i]>0) && (y[i]<=ymax/10))  y[i]=0;
    if ((y[i]<0) && (y[i]>=ymin/10))  y[i]=0;
void PrintArray2(string caption) {
   int i, j, k;
   char ExitBtnSwitchMode=1;    // toggle between ^home and ^end
   float  scale  = 1;
   string FmtStr = "%6.3f ";
   printf1(0,LCDline[0], "%s", caption);
   printf1(0,LCDline[1], "%s", "idx  [x]    [y]");
   i=j=k=0;
   while(j<ArrLen) {
     k=0;
     for (i=0; i<6; ++i) {
       if (j<ArrLen) {
          printf1( 0, LCDline[i+2], "%d   ", j);
          printf1(18, LCDline[i+2], FmtStr, x[j]*scale);
          printf1(60, LCDline[i+2], FmtStr, y[j]*scale);
          ++k;
       ++j;
     if (k<5) {
       while (k<6) {
         printf1(0,LCDline[k+2], "%s", "                    ");
         ++k;
     while  (!btnhit());
     if (ButtonPressed(BTNLEFT, false)) {      // scroll back
       j=j-12;
       if (j<0) j=0;
       if (btnhit()) Wait(300);
     if (ButtonPressed(BTNRIGHT, false)) {     // scroll fwd
       if (j>ArrLen-5) j=ArrLen-5;
       if (j<0) j=0;
       if (j>=ArrLen-5) printf1(0,LCDline[7], "%s", "quit: BtnCenter ");
     if (ButtonPressed(BTNCENTER, false)) {    // quit
       while  (btnhit());
       if (j<ArrLen-1) j=j-6;
       if (j<0) j=0;
     if (ButtonPressed(BTNEXIT, false)) {      // last <-> first
       if (ExitBtnSwitchMode) {
         j=ArrLen-5;
         if (j<0) j=0;
       else {
         j=0;
       ExitBtnSwitchMode^=1;
       while (btnhit());
void PressToContinue(char Button) {
   string msg;
   if (Button==BTNCENTER)   msg="press BtnCntr...";
   if (Button==BTNEXIT)     msg="press BtnExit...";
   if (Button==BTNRIGHT)    msg="press BtnRight...";
   if (Button==BTNLEFT)     msg="press BtnLeft...";
   printf1(0,LCDline[7],"%s", msg);
   while (!ButtonPressed(Button, false)); while (btnhit());
task main() {
   int i;
   char ch;
   SetAbortFlag(BTNSTATE_NONE);
   FillArraySin();  //  initialize by test values
   PrintArray2(" FillArraySin()");
   FFT(+1);  //  forward FFT
   //PressToContinue(BTNCENTER);
   PrintArray2(" FFT(+1) ");
   ExtremizeArray();
   PrintArray2(" Extract 1 ");
   SetAbortFlag(BTNSTATE_PRESSED_EV);
   PressToContinue(BTNEXIT);
   while(1);
It appears that the enhanced NBC/NXC firmware's ARROP opcode is a bit buggy. I am working on fixes to support arrays containing floating point values.
Please try the new test release (firmware and compiler changes) that should fix the problems described in this thread.
I have not updated the history.txt or bricxcc release notes or the help file yet. I will work on those this coming week.
Also in this release are a new JoystickMessageType structure and JoystickMessageRead API function that work with recently made enhancements to the BricxCC Joystick tool which allow you to change the tool from its default mode of directly controlling the motors to sending a message whenever motor direction and speed or joystick button states are changed.
Also in this release is support for the new RandomEx enhanced NBC/NXC firmware random number system call. This new system call is used when you target the enhanced firmware and you call the srand and rand functions.
John, thx, I'll try it out immediately.
BTW: why do you permanently call your fw versions 1.31? Don't you have any other numbers on your keyboard? (if so I can send you one of mine via UPS^^)
on the other hand, maybe you wish to switch to Donald Knuth's system instead: "Version numbers of his TeX software approach the number π, in that versions increment in the style 3, 3.1, 3.14. 3.141, and so on. Similarly, version numbers of Metafont approach the base of the natural logarithm, e." (Wikipedia)
I tried it out:
files copied into programs\bricxcc
fw uploaded to NXT
code snippet:
  int i;
  printf1(0,56, "%s", "ArrayMax/Min");      // <<<<<<<<<<  TEST ArrayMax/Min
  printf1(0,40, "xmax=%6.3f", xmax);
  printf1(0,32, "xmin=%6.3f", xmin);
  printf1(0,24, "ymax=%6.3f", ymax);
  printf1(0,18, "ymin=%6.3f", ymin);
  while (!btnhit());
  //...*SNIP*
edit:
confusing the fw versions... :evil:
why are they all named 1.31 ??? :evil: :evil: :evil:
now it's fine!
ArrayMax 0.jpg (11.97 KiB) Viewed 12816 times
I will probably someday increment the firmware version number. Please forgive me for not wanting to completely deviate from the version number of the standard firmware from which the enhanced firmware was created.
