Hi everyone,
I'm working on a traction control type system for a school project. I recently purchased a Hitechnic accelerometer sensor and would like to intgrate the output. I'm using Labview to create the code, however, it doesn't appear that there is an integration block available.
Has anyone run into the before? Does anyone have any suggestions how I can integrate the sensor output?
I appreciate your comments.
Thanks
Vehicle Control System - Need to Integrate
Re: Vehicle Control System - Need to Integrate
Try here to start: http://www.hitechnic.com/downloadnew.php?category=17
stryker001
What, exactly, are you trying to use the accelerometer data for? I'm curious.
- Stryker AKA Jordan
http://nxtbystryker.wordpress.com
integrating acceleration once * dt: => speed
integrating acceleration twice * dt: => distance (position)
