Ultrasonic Sensor Not Working?
I'm trying to make a simple robot that drives around a room without running in to obstacles by using its ultrasonic sensor but the sensor is giving me completely random readings. When I have it only print out its readings on the LCD screen it seems to work well but when I use it in my program the robot will do anything from run straight into a wall to stop 4ft in front of it. Is there anything wrong with my sensor and if so, what can I do?
Re: Ultrasonic Sensor Not Working?
Hi there,
It might help if you gave us a look at your program. Maybe it's something unrelated to the sensor that is causing this erratic behaviour
I thought of that but my code seemed pretty straight forward. Here it is though, maybe I missed something...
package rover;
import lejos.nxt.*;
import lejos.robotics.navigation.*;
public class Rover {
static UltrasonicSensor us = new UltrasonicSensor(SensorPort.S4);
static DifferentialPilot sc = new DifferentialPilot(5.6F, 13F, Motor.C, Motor.A, true);
* @param args
public static void main(String[] args) {
// TODO Auto-generated method stub
sc.setTravelSpeed(700);
sc.backward();
while(!Button.ESCAPE.isPressed()){
if (us.getDistance() < 45){
sc.stop();
}Re: Ultrasonic Sensor Not Working?
I wrapped your code in some code tags like this:
[/code]
You should do that next time you paste it into a post, makes a lot more readable
As for your code, I am not all that familiar with Lejos, but you're right, there doesn't seem to be anything really weird there. What are you bouncing the US off? Is it a hard or soft surface?
[code]
your code
Ok I'll try that with the code from now on, thanks.
At first I was just testing using my hand in front of the sensor but I also tried running it up to some hard wood furniture and they both would give the same random results.
