[NXC] Can I querey a string to determine it's case?
dodgey
Post by dodgey »
Hi - I want to query a text string and see if the result is either..
Upper case
Lower case
Numeric
Is this possible? (irrelevent of the content, I just want to know case or numeric)
Otherwise I've got to query the string value and "say" if it's any one character of "DURLBF" or "123456" or "durlbf" then do something.
Re: [NXC] Can I querey a string to determine it's case?
enum szcase
{ none = 0, upper, lower, both, num };
int n;
string sz = "this is a string";
szcase sc = none;
if(sscanf(sz, "%d", n) == EOF)
    for(unsigned int i = 0; i < strlen(sz); ++i)
        if(sz[i] >= 'A' && sz[i] <= 'Z')
            sc |= upper;
        if(sz[i] >= 'a' && sz[i] <= 'z')
            sc |= lower;
    sc = num;
    NumOut(0, 0, num, 0);
I'm not sure if NXC supports sscanf()...
dodgey
Post by dodgey »
Wonderful! Many thanks. I'll have a play.
Even if scanf isn't supported I didn't realise you could "do" <>A-Z <>a-z etc,
... in fact, my string will only ever contain one character/numeral, so I can just use. coolio!
if(sz >= 'A' && sz <= 'Z')
sc |= upper;
if(sz >= 'a' && sz <= 'z')
sc |= lower;
sc = num;
Read the character one time from the string like this:
char ch = sz[0]; // the one and only character in the string
Then, if you want, you can use the standard library ctype routines for checking characters.
http://bricxcc.sourceforge.net/nbc/nxcd ... ample.html
e.g., isupper, islower, isdigit
You don't need the OR-equal stuff (|=) since you are only looking at a single character.
Oh, right, forgot about those nifty little is_()s.
char ch = sz[0];
if(isdigit(ch)) {
else if(isupper(ch)) {
else if(islower(ch)) {
else {
