Grabbot
Grabbot
Hello. I need some help. I have problems with grabbot. Robot who will take and lift ball or basket(of lego-blocks). Can u sent me some images or give me interesting idea. For example: http://www.laurensvalk.com/includes/nxt ... /main1.jpg. But it is too difficult to build. Help me
Re: Grabbot
May be u have a building instruction of this NXT Robot. If u have pls give me url
Re: Grabbot
You probably have to buy this book - http://www.laurensvalk.com/nxt-1_0-only/grabbot
http://www.amazon.com/LEGO-MINDSTORMS-N ... 593271883/
pepijndevos
Re: Grabbot
Depending on what you want, this one might work: http://studl.es/2012/01/pincer-bot/
-- Pepijn
Re: Grabbot
Actually, the one he posted the photo of is the 2.0 version - http://www.laurensvalk.com/nxt-2_0-only/the-snatcher, which is in the book http://www.amazon.com/LEGO-MINDSTORMS-N ... 866&sr=8-1
It is quite complicated, although easy enough to build with his instructions.
McSummation aka James
Re: Grabbot
The snatcher is a fantastic robot. I used it as a base for my Pneumo-Snatcher
pepijndevos
Re: Grabbot
Interesting, how do you switch the pumps?
Is the secret inside the black box?
I have tried to make some sort of binary switch, to control an unlimited number of switches with one motor. But I have not succeeded at that so far.
-- Pepijn
Re: Grabbot
You mean switch the valves? He used the Servo Operated Pneumatic Valve Kit from mindsensors.
Re: Grabbot
He sure did! The accompanying article is here: [LINK]mattallen37 wrote:You mean switch the valves? He used the Servo Operated Pneumatic Valve Kit from mindsensors.
pepijndevos
Re: Grabbot
Ohnoes! The valves are out of stock
I wonder if you can connect a regulator to the servo controller. Insane amounts of brushless power!
-- Pepijn
