I am confusing "OnFwdReg"
walduss
Post by walduss »
Hi
I am starting with NXC. I have a code but I am confusing, so I have reduced my code to minimun.
I will show ..
#define SPIN_SPEED  50
// NXT Port aliases
#define WHEELS            OUT_BC
#define LEFT_WHEEL        OUT_B
#define RIGHT_WHEEL       OUT_C
#define CW     1        // clockwise
#define ACW   -1        // anticlockwise
void Spin(short dir)
	// Gira hacia el lado de "dir"
	// Usar CW o ACW
	NumOut(0, LCD_LINE4, dir);
	NumOut(0, LCD_LINE5, sign(dir));
	OnFwdReg(LEFT_WHEEL,  -sign(dir)*SPIN_SPEED, OUT_REGMODE_IDLE );
	OnFwdReg(RIGHT_WHEEL, sign(dir)*SPIN_SPEED, OUT_REGMODE_IDLE );
	OnFwdReg(LEFT_WHEEL,  dir*10, OUT_REGMODE_IDLE );
	OnFwdReg(RIGHT_WHEEL, -dir*10, OUT_REGMODE_IDLE );
  Spin(CW);
  Wait(3000);
this code work fine, but If I change the main task to
  Spin(ACW);
  Wait(3000);
program do nothing !!! For me it is suppose that Wheels run in oposite direction!!!! (Robot should spin oposite than before)
another test ... If I change main task to ...
  Spin(CW);
  Wait(3000);
  Spin(ACW);
  Wait(3000);
or ....
  Spin(ACW);
  Wait(3000);
  Spin(CW);
  Wait(3000);
It runs fine too !!!
So why programn dont work when I try to Spin ACW (AnticlockWise) only ????
thanks in advance and sorry for my english!
walduss
Re: I am confusing "OnFwdReg"
Post by walduss »
Hi again,
I have done another test after restart the brick and the computer.
// NXT Port aliases
	// Rotot turn to "dir" direction
	// Use CW o ACW
  TextOut(0, LCD_LINE5, "Left done");
  TextOut(0, LCD_LINE6, "Right done");
  Spin(ACW);
  Wait(3000);
in this case Numer "-1" is display in line4 and but never it is shown the text "Left done". also the program never end.
But if I call Spin(CW) instead Spin(ACW) in main task, Program run sucessfully.
Anybody have any clue?
walduss
Post by walduss »
After some test I have discover hat the issue is due to "sign" function.
When NXT run "-sign(dir)" where "dir" is ACW the program get an unexpected behaviour (at least for me)
So I have remove sign function (really, it was not necessary)
// NXT Port aliases
// Usar CW o ACW
OnFwdReg(LEFT_WHEEL, (dir)*SPIN_SPEED, OUT_REGMODE_SPEED );
OnFwdReg(RIGHT_WHEEL, -(dir)*SPIN_SPEED, OUT_REGMODE_SPEED );
Spin(ACW);
Wait(3000);
Now, program seem to be fine.
But really I dont know if the issue with -sign(dir) is a bug or not. If anyone could confirm it will be apreciated.
I agree, OnFwdReg is weird and often produces unexpected behaviours -
(to be honest: just like all of the advanced motor functions ...)
I personally sacrificed all of them.
Better you write your own functions!
walduss
Post by walduss »
doc-helmut wrote:I agree, OnFwdReg is weird and often produces unexpected behaviours -
Sorry, I dont understand what you mean with create your own functions?
You mean create in a low level lenguage like NCB?
Now I am having more issues with other secuences of program, so any help will be usefull!
If I were you, I would use OnFwd and/or OnRev.
yes, matt wrote what I actually intended to say.
walduss
Post by walduss »
mattallen37 wrote:If I were you, I would use OnFwd and/or OnRev.
doc-helmut wrote:yes, matt wrote what I actually intended to say.
Ok, I understand. In fact actually I am using OnFwd and OnRev instead.
Anyway, as I have comment before, after some test I have detected that issue was related to Sign fuction.
Thanks.
to my observations, the sign() function always works correctly.
But not everything which normally works correctly does work also properly and predictalbly when used by the advanced motor control functions...
